Gönderen Konu: [Çözüldü] cinnamon is currently running without video hardware acceleration  (Okunma sayısı 11431 defa)
Çevrimdışı ysfbkrcn
  • İleti: 26
  • Dağıtım: Linux Mint 18
  • Grafik Kartı: Nvidia 940mx
  • İşlemci: intel i5 7200u
Ekran kartımla alakalı sorun yaşıyorum.
Driver Manager'den "xserver-xorg-video-nouveau (open-source)" seçtiğim zaman şöyle bir uyarı alıyorum.
Running in software rendering mode
Cinnamon is currently running without video hardware acceleration and, as a result, you may observe much higher than normal CPU usage.
There could be a problem with your drivers or some other issue. For the best experience, it is recommended that you only use this mode for troubleshooting purposes.
Farklı bir ekran kartı sürücüsü seçersem, nvidia-381 ya da nvia-371 de cinnamon çalışmayı durduruyor. Forumdaki ve internetteki önerilen çözümleri denedim ama bir çözüme ulaşamadım.
yusuf@y560 ~ $ inxi -SGx
System:    Host: y560 Kernel: 4.4.0-21-generic x86_64 (64 bit gcc: 5.3.1)
           Desktop: Cinnamon 3.2.7 (Gtk 3.18.9-1ubuntu3.3) Distro: Linux Mint 18.1 Serena
Graphics:  Card-1: Intel Device 5916 bus-ID: 00:02.0
           Card-2: NVIDIA Device 179c bus-ID: 01:00.0
           Display Server: X.Org 1.18.4 drivers: fbdev,intel (unloaded: vesa) Resolution: 1366x768@76.00hz
           GLX Renderer: Gallium 0.4 on llvmpipe (LLVM 3.8, 256 bits)
yusuf@y560 ~ $ glxinfo | grep render
OpenGL renderer string: Gallium 0.4 on llvmpipe (LLVM 3.8, 256 bits)
yusuf@y560 ~ $ lspci | egrep 'VGA|3D|Display'
00:02.0 VGA compatible controller: Intel Corporation Device 5916 (rev 02)
01:00.0 3D controller: NVIDIA Corporation Device 179c (rev a2)
yusuf@y560 ~ $ xrandr
Screen 0: minimum 1366 x 768, current 1366 x 768, maximum 1366 x 768
default connected primary 1366x768+0+0 0mm x 0mm
   1366x768      76.00*
yusuf@y560 ~ $ cat /etc/X11/xorg.conf
# nvidia-xconfig: X configuration file generated by nvidia-xconfig
# nvidia-xconfig:  version 340.102  (buildmeister@swio-display-x64-rhel04-19)  Mon Jan 16 13:23:00 PST 2017
Section "ServerLayout"
    Identifier     "Layout0"
    Screen      0  "Screen0"
Section "Files"
Section "InputDevice"
    # generated from default
    Identifier     "Mouse0"
    Driver         "mouse"
    Identifier     "Keyboard0"
    Driver         "kbd"
Section "Monitor"
    Identifier     "Monitor0"
    VendorName     "Unknown"
    ModelName      "Unknown"
    HorizSync       28.0 - 33.0
    VertRefresh     43.0 - 72.0
    Option         "DPMS"
    Identifier     "Device0"
    Driver         "nvidia"
Section "Screen"
    Identifier     "Screen0"
    Device         "Device0"
    Monitor        "Monitor0"
    DefaultDepth    24
    SubSection     "Display"
        Depth       24
    EndSubSection
yusuf@y560 ~ $ dpkg -l | egrep 'nvidia|bumblebee|primus|prime|virtualgl|fglrx'
rc  nvidia-304                                   304.135-0ubuntu0.16.04.1                    amd64        NVIDIA legacy binary driver - version 304.135
rc  nvidia-340                                   340.102-0ubuntu0.16.04.2                    amd64        NVIDIA binary driver - version 340.102
rc  nvidia-381                                   381.22-0ubuntu0~gpu16.04.2                  amd64        NVIDIA binary driver - version 381.22
rc  nvidia-opencl-icd-381                        381.22-0ubuntu0~gpu16.04.2                  amd64        NVIDIA OpenCL ICD
ii  nvidia-prime                                 0.8.2linuxmint1                             amd64        Tools to enable NVIDIA's Prime
ii  nvidia-settings                              381.22-0ubuntu0~gpu16.04.1                  amd64        Tool for configuring the NVIDIA graphics driver
« Son Düzenleme: 14 Haziran 2017, 14:45:38 Gönderen: ysfbkrcn »
Çevrimdışı ysfbkrcn
  • İleti: 26
Ynt: cinnamon is currently running without video hardware acceleration
« Yanıtla #2 : 13 Haziran 2017, 18:54:07 »
ilk mesajı güncelledim.
« Yanıtla #3 : 13 Haziran 2017, 19:28:30 »
Aşağıdaki komutu uçbirimde çalıştırıp sisteminizi yeniden başlatınız, Intel + Nvidia hibrit GPU olan sistemlerde nvidia-xconfig ile xorg.conf yapılandırma dosyası oluşturmamalısınız.
sudo rm -f /etc/X11/xorg.conf
Çevrimdışı ysfbkrcn
  • İleti: 26
« Yanıtla #4 : 13 Haziran 2017, 19:36:32 »
hala aynı uyarıyı almaktayım.
bu arada X11 dizininden silmem gereken başka bir şeyler olabilir mi?
yusuf@y560 /etc/X11 $ ls
app-defaults             fonts    xinit  xorg.conf.backup                   Xreset    Xresources  Xsession.d        xsm
default-display-manager  rgb.txt  xkb    xorg.conf.nvidia-xconfig-original  Xreset.d  Xsession    Xsession.options  Xwrapper.config
sistem bilgilerimi ekliyorum. forumdaki diğer konularını inceledim ve anladığım kadarıyla sorun "yazılımsal işleme etkin" olmasından kaynaklı. fakat çözümler amd kartlar için sunulmuş. nvidia kartları için hangi komutları çalıştırmam gerektiğini bilmiyorum.
           Desktop: Cinnamon 3.2.7 (Gtk 3.18.9-1ubuntu3.3) dm: mdm Distro: Linux Mint 18.1 Serena
Machine:   Mobo: Acer model: Captain_SK v: V1.25 Bios: Insyde v: V1.25 date: 03/03/2017
CPU:       Dual core Intel Core i5-7200U (-HT-MCP-) cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 10849
           clock speeds: min/max: 400/2601 MHz 1: 1900 MHz 2: 1400 MHz 3: 1500 MHz 4: 1400 MHz
Graphics:  Card-1: Intel Device 5916 bus-ID: 00:02.0 chip-ID: 8086:5916
           Card-2: NVIDIA Device 179c bus-ID: 01:00.0 chip-ID: 10de:179c
Audio:     Card Intel Device 9d71 driver: snd_hda_intel bus-ID: 00:1f.3 chip-ID: 8086:9d71
Network:   Card-1: Qualcomm Atheros Device 0042 driver: ath10k_pci bus-ID: 03:00.0 chip-ID: 168c:0042
           IF: wlp3s0 state: up speed: N/A duplex: N/A mac: <filter>
           driver: r8169 v: 2.3LK-NAPI port: 3000 bus-ID: 04:00.1 chip-ID: 10ec:8168
           IF: enp4s0f1 state: down mac: <filter>
Drives:    HDD Total Size: 750.2GB (25.1% used)
           ID-1: /dev/sda model: ST9500420AS size: 500.1GB serial: 5VJ97ZP8
           ID-2: /dev/sdb model: Samsung_SSD_850 size: 250.1GB serial: S21PNSAG734432H
Partition: ID-1: / size: 226G used: 172G (81%) fs: ext4 dev: /dev/sdb5
           ID-2: swap-1 size: 4.09GB used: 0.00GB (0%) fs: swap dev: /dev/sdb1
           Unused Devices: none
Sensors:   System Temperatures: cpu: 56.0C mobo: N/A
Repos:     Active apt sources in file: /etc/apt/sources.list.d/docker.list
           deb [arch=amd64] https: //apt.dockerproject.org/repo debian-stretch main
           Active apt sources in file: /etc/apt/sources.list.d/erlang-solutions.list
           deb http: //binaries.erlang-solutions.com/debian squeeze contrib
           Active apt sources in file: /etc/apt/sources.list.d/flexiondotorg-youtube-dl-gui-xenial.list
           deb http: //ppa.launchpad.net/flexiondotorg/youtube-dl-gui/ubuntu xenial main
           deb-src http: //ppa.launchpad.net/flexiondotorg/youtube-dl-gui/ubuntu xenial main
           Active apt sources in file: /etc/apt/sources.list.d/github_git-lfs.list
           deb https: //packagecloud.io/github/git-lfs/linuxmint/ sarah main
           deb-src https: //packagecloud.io/github/git-lfs/linuxmint/ sarah main
           Active apt sources in file: /etc/apt/sources.list.d/google-chrome.list
           deb [arch=amd64] http: //dl.google.com/linux/chrome/deb/ stable main
           Active apt sources in file: /etc/apt/sources.list.d/graphics-drivers-ppa-xenial.list
           deb http: //ppa.launchpad.net/graphics-drivers/ppa/ubuntu xenial main
           deb-src http: //ppa.launchpad.net/graphics-drivers/ppa/ubuntu xenial main
           Active apt sources in file: /etc/apt/sources.list.d/mongodb-org-3.2.list
           deb http: //repo.mongodb.org/apt/ubuntu xenial/mongodb-org/3.2 multiverse
           Active apt sources in file: /etc/apt/sources.list.d/nemh-systemback-xenial.list
           deb http: //ppa.launchpad.net/nemh/systemback/ubuntu xenial main
           deb-src http: //ppa.launchpad.net/nemh/systemback/ubuntu xenial main
           Active apt sources in file: /etc/apt/sources.list.d/numix-ppa-xenial.list
           deb http: //ppa.launchpad.net/numix/ppa/ubuntu xenial main
           deb-src http: //ppa.launchpad.net/numix/ppa/ubuntu xenial main
           deb http: //packages.linuxmint.com serena main upstream import backport #id:linuxmint_main
           deb http: //archive.ubuntu.com/ubuntu xenial main restricted universe multiverse
           deb http: //archive.ubuntu.com/ubuntu xenial-updates main restricted universe multiverse
           deb http: //archive.ubuntu.com/ubuntu xenial-backports main restricted universe multiverse
           deb http: //security.ubuntu.com/ubuntu/ xenial-security main restricted universe multiverse
           deb http: //archive.canonical.com/ubuntu/ xenial partner
           Active apt sources in file: /etc/apt/sources.list.d/qbittorrent-team-qbittorrent-stable-xenial.list
           deb http: //ppa.launchpad.net/qbittorrent-team/qbittorrent-stable/ubuntu xenial main
           deb-src http: //ppa.launchpad.net/qbittorrent-team/qbittorrent-stable/ubuntu xenial main
           Active apt sources in file: /etc/apt/sources.list.d/ravefinity-project-ppa-xenial.list
           deb http: //ppa.launchpad.net/ravefinity-project/ppa/ubuntu xenial main
           deb-src http: //ppa.launchpad.net/ravefinity-project/ppa/ubuntu xenial main
           Active apt sources in file: /etc/apt/sources.list.d/spotify.list
           deb http: //repository.spotify.com stable non-free
           Active apt sources in file: /etc/apt/sources.list.d/team-xbmc-ppa-xenial.list
           deb http: //ppa.launchpad.net/team-xbmc/ppa/ubuntu xenial main
           deb-src http: //ppa.launchpad.net/team-xbmc/ppa/ubuntu xenial main
           Active apt sources in file: /etc/apt/sources.list.d/webupd8team-java-xenial.list
           deb http: //ppa.launchpad.net/webupd8team/java/ubuntu xenial main
           deb-src http: //ppa.launchpad.net/webupd8team/java/ubuntu xenial main
           Active apt sources in file: /etc/apt/sources.list.d/zanchey-asciinema-xenial.list
           deb http: //ppa.launchpad.net/zanchey/asciinema/ubuntu xenial main
           deb-src http: //ppa.launchpad.net/zanchey/asciinema/ubuntu xenial main
Info:      Processes: 254 Uptime: 4 min Memory: 2134.8/7851.8MB
           Client: Unknown python2.7 client inxi: 2.2.35
« Son Düzenleme: 13 Haziran 2017, 19:56:58 Gönderen: ysfbkrcn »
« Yanıtla #5 : 13 Haziran 2017, 20:45:19 »
Başaka silmeniz gereken bir dosya yok, aşağıdaki komutla Nvidia ile ilgili sürücüleri kaldırıp sistemi yeniden başlatmayı deneyiniz.
sudo apt-get purge nvidia*
sudo apt-get purge bbswith-dkms
Çevrimdışı ysfbkrcn
  • İleti: 26
« Yanıtla #6 : 13 Haziran 2017, 21:00:05 »
son komutun çıktısı şu şekilde. şimdi yeniden başlatıyorum.
yusuf@y560 ~ $ sudo apt-get purge bbswith-dkms
Reading package lists... Done
Building dependency tree
E: Unable to locate package bbswith-dkms
aynı uyarıyı almaya devam ediyorum.
« Son Düzenleme: 13 Haziran 2017, 21:01:53 Gönderen: ysfbkrcn »
« Yanıtla #7 : 13 Haziran 2017, 21:58:33 »
Sistemi yeniden başlatmadıysanız, önce yeniden başlatın ve ekran kartı ile ilgili ilgili çıktıları yeniden başlatın. Sorunun çözümü zor değil, şu an sistem yazılımsal işleme kipi ile destek sunan sürücüyle (llvmpipe) çalıştığı için bu hatayı alıyorsunuz. Önce çıktıları görelim, sonra yönlendirme yapalım.
Çevrimdışı ysfbkrcn
  • İleti: 26
« Yanıtla #8 : 13 Haziran 2017, 22:07:51 »
   1366x768      76.00*
alttaki komut herhangi bir sonuç döndürmedi.
« Yanıtla #9 : 13 Haziran 2017, 22:10:10 »
Aşağıdaki komutu uçbirimde çalıştırıp sistemi yeniden başlatmayı deneyiniz.
sudo mkdir -p /etc/X11/xorg.conf.d/ && echo -e 'Section "Device"\n Identifier "Intel Graphics"\n Driver "Intel"\n Option "AccelMethod" "sna"\n Option "TearFree" "true"\nEndSection' | sudo tee /etc/X11/xorg.conf.d/20-intel.conf
Çevrimdışı ysfbkrcn
  • İleti: 26
« Yanıtla #10 : 13 Haziran 2017, 22:15:00 »
« Yanıtla #11 : 13 Haziran 2017, 22:18:19 »
Aşağıdaki komutu uçbirimde çalıştırınız,
cinnamon --replace 2> cinnamon
bu komut kullanıcı ev dizini içinde cinnamon isminde bir dosya oluşturacak.
Bu dosyayı açıp, içeriğini kod etiketi içinde foruma yapıştırınız.
Çevrimdışı ysfbkrcn
  • İleti: 26
« Yanıtla #12 : 13 Haziran 2017, 22:20:36 »
Window manager warning: Software rendering detected: Gallium 0.4 on llvmpipe (LLVM 3.8, 256 bits)
Cjs-Message: JS LOG: About to start Cinnamon
Cjs-Message: JS LOG: ACTIVATING SOFTWARE RENDERING
St-Message: cogl npot texture sizes SUPPORTED
Cjs-Message: JS LOG: Cinnamon started at Tue Jun 13 2017 22:19:24 GMT+0300
Window manager warning: Log level 16: Attempting to read the recently used resources file at '/home/yusuf/.local/share/recently-used.xbel', but the parser failed: Failed to open file '/home/yusuf/.local/share/recently-used.xbel': Permission denied.
Cjs-Message: JS LOG: network applet: Cannot find connection for active (or connection cannot be read)
openGL version 3.3 detected (GL3 Cogl Driver)
MetaSyncRing disabled: couldn't find required GL extensions, or the minimum safe openGL version was not met
Window manager warning: Log level 16: STACK_OP_REMOVE: window 0x40 not in stack
Cjs-Message: JS LOG: Invalid network device type, is 13
Cjs-Message: JS LOG: Invalid network device type, is 14
Cjs-Message: JS LOG: network applet: Found connection for active
« Yanıtla #13 : 13 Haziran 2017, 22:27:04 »
Buradaki öneriyi dener misiniz?
Çevrimdışı ysfbkrcn
  • İleti: 26
« Yanıtla #14 : 13 Haziran 2017, 22:33:01 »
bunu daha önceden zaten denemiştim ve tekrar denedim. şu anda mate arayüzünden yazıyorum ama "direct rendering" devam ediyor.
pencereler arasında geçiş yaparken ekran yenileme hızı çok düşük. yukarıdan aşağıya doğru parça parça görüntü geliyor. cinnamon'da da bu şekildeydi.
