Gönderen Konu: [Çözüldü] Ralink MT7601U Wireless Adapter Bağlantı sorunu  (Okunma sayısı 3483 defa)
Çevrimdışı indirdivx1967
  • İleti: 183
  • Grafik Kartı: Device-1: Intel vendor: Acer Incorporated ALI
  • İşlemci: Dual Core model: Intel Celeron N4000 bits: 64 type
Modem e sorunsuz bağlanıyor  ip alıyor ama internet'e  bağlanamıyor  benzer usb  Wireless Adapter var  power on yazıyor bunda power off. cihaz  windows 10  sorunsuz çalışıyor
System:    Host: frisby-System-Product-Name Kernel: 4.4.0-79-generic x86_64 (64 bit gcc: 5.4.0)
           Desktop: MATE 1.16.1 (Gtk 3.18.9-1ubuntu3.3) dm: mdm
Network:   Card-1: NVIDIA MCP61 Ethernet
           driver: forcedeth port: e480 bus-ID: 00:07.0 chip-ID: 10de:03ef
           IF: enp0s7 state: up speed: 100 Mbps duplex: full mac: <filter>
           Card-2: Ralink MT7601U Wireless Adapter
           driver: mt7601u usb-ID: 001-003 chip-ID: 148f:7601
           IF: wlx20e117028b29 state: N/A mac: N/A
0:07.0 Bridge [0680]: NVIDIA Corporation MCP61 Ethernet [10de:03ef] (rev a2)
Subsystem: ASUSTeK Computer Inc. MCP61 Ethernet [1043:8234]
Kernel driver in use: forcedeth
Kernel modules: forcedeth
Bus 001 Device 003: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter
Bus 002 Device 007: ID 04d9:1503 Holtek Semiconductor, Inc. Keyboard
Bus 002 Device 006: ID 045e:07b2 Microsoft Corp.
0: phy0: Wireless LAN
Soft blocked: no
Hard blocked: no
[  *-network
       açıklama: Kablosuz arayüz
       physical id: 1
       bus info: usb[member=3516]1[/member]:4
       mantıksal ad: wlx20e117028b29
       serial: 20:e1:17:02:8b:29
       yapılandırma: broadcast=yes driver=mt7601u driverversion=4.4.0-79-generic firmware=N/A ip=192.168.1.104 link=yes multicast=yes wireless=IEEE 802.11bgn/code]
[code]lo        no wireless extensions.
enp0s7    no wireless extensions.
          Bit Rate=30 Mb/s   Tx-Power=20 dBm
          Power Management:off
« Son Düzenleme: 22 Haziran 2017, 20:28:14 Gönderen: indirdivx1967 »
Ynt: Ralink MT7601U Wireless Adapter Bağlantı sorunu
« Yanıtla #1 : 21 Haziran 2017, 23:15:20 »
Forumdaki konuları incelediniz mi?
  • İleti: 183
« Yanıtla #2 : 21 Haziran 2017, 23:45:18 »
uyarınız üzerine  kırmızı ile işaretlenen kısmı arattım   aşağıdaki komutları buldum ve uyguladım  şu anda  wriless  hiç çalışmıyor :(
sudo add-apt-repository ppa:thopiekar/mt7601
sudo apt-get install mt7601-sta-dkms
« Yanıtla #3 : 21 Haziran 2017, 23:46:44 »
Sistemi yeniden başlatınız mı peki?
  • İleti: 183
« Yanıtla #4 : 21 Haziran 2017, 23:48:13 »
evet  cihazı takıp çıkarıyım mı
System:    Host: frisby-System-Product-Name Kernel: 4.4.0-81-generic x86_64 (64 bit gcc: 5.4.0)
           driver: rt2870 usb-ID: 001-002 chip-ID: 148f:7601
           IF: ra0 state: down mac: <filter>
00:07.0 Bridge [0680]: NVIDIA Corporation MCP61 Ethernet [10de:03ef] (rev a2)
[Bus 001 Device 002: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter
Bus 002 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub/code][code] hiç bir şey vermedi
cfg80211              565248  0
nvidia              11407360  48
mt7601Usta            602112  0
snd_hda_codec         135168  3 snd_hda_codec_realtek,snd_hda_codec_generic,snd_hda_intel
snd_hda_core           73728  4 snd_hda_codec_realtek,snd_hda_codec_generic,snd_hda_codec,snd_hda_intel
snd_pcm               106496  3 snd_hda_codec,snd_hda_intel,snd_hda_core
kvm_amd                65536  0
kvm                   544768  1 kvm_amd
drm                   364544  2 nvidia
snd                    81920  16 snd_hda_codec_realtek,snd_hwdep,snd_timer,snd_pcm,snd_seq,snd_rawmidi,snd_hda_codec_generic,snd_hda_codec,snd_hda_intel,snd_seq_device
amd64_edac_mod         32768  0
k8temp                 16384  0
edac_mce_amd           24576  1 amd64_edac_mod
edac_core              53248  2 amd64_edac_mod
i2c_nforce2            16384  0
asus_atk0110           20480  0
ip6t_REJECT            16384  1
nf_log_ipv6            16384  5
xt_hl                  16384  22
nf_conntrack_ipv6      20480  8
nf_defrag_ipv6         36864  1 nf_conntrack_ipv6
ipt_REJECT             16384  1
nf_log_ipv4            16384  5
nf_log_common          16384  2 nf_log_ipv4,nf_log_ipv6
xt_LOG                 16384  10
xt_limit               16384  13
xt_tcpudp              16384  18
nf_conntrack_ipv4      16384  8
xt_conntrack           16384  16
ip6_tables             28672  1 ip6table_filter
nf_nat                 24576  1 nf_nat_ftp
nf_conntrack_ftp       20480  1 nf_nat_ftp
nf_conntrack          106496  8 nf_nat_ftp,nf_conntrack_netbios_ns,nf_nat,xt_conntrack,nf_conntrack_broadcast,nf_conntrack_ftp,nf_conntrack_ipv4,nf_conntrack_ipv6
ip_tables              24576  1 iptable_filter
x_tables               36864  13 ip6table_filter,xt_hl,ip_tables,xt_tcpudp,xt_limit,xt_conntrack,xt_LOG,iptable_filter,ip6t_rt,ipt_REJECT,ip6_tables,xt_addrtype,ip6t_REJECT
sata_nv                32768  2
forcedeth              69632  0
pata_amd               20480  0
floppy                 73728  0
son durum
« Son Düzenleme: 21 Haziran 2017, 23:57:00 Gönderen: indirdivx1967 »
« Yanıtla #5 : 22 Haziran 2017, 09:37:04 »
Aşağıdaki komutlarla kurduğunuz paketi kaldırıp yeniden başlatmayı deneyiniz.
sudo apt-get purge mt7601-sta-dkms
sudo rm -f /etc/apt/sources.list.d/*mt7601*
Sonrasında duruma göre yönlendirme yapalım.
  • İleti: 183
Ynt: [Çözüldü] Ralink MT7601U Wireless Adapter Bağlantı sorunu
« Yanıtla #6 : 22 Haziran 2017, 20:28:48 »
ellerine sağlık çözüldü üstad
« Yanıtla #7 : 23 Haziran 2017, 09:14:30 »
Aslında sorunun bu şekilde çözülmemesi gerekir, şu an sadece PPA deposundan yüklemeyi denediğimiz sürücüyü kaldırmış oldunuz. Konu açık kalsın, durumu kontrol edip geri bildiriminize göre çekirdek güncellemesi ya da Github vb. bir ortamdan bulabileceğiniz sahipli sürücüyü elle kurmaya yönlendirebiliriz.
