Gönderen Konu: [Çözüldü] Kworker; aşırı CPU kullanımı  (Okunma sayısı 5160 defa)
Çevrimdışı topal karga
  • İleti: 63
  • ex nihilo nihil fit!
  • Dağıtım: Mint 119.2 Mate 64 Bit
« : 10 Temmuz 2017, 09:08:52 »
Merhaba, mint 18.2 upgrade sonrası eski çekirdeklerden bazılarını sildim. Sonuç olarak kworker cpu kullanımı %100'lere dek çıkıyor. Ne önerirsiniz?
dpkg -l | grep $(uname -r)
ii  linux-headers-4.10.0-26-generic                             4.10.0-26.30~16.04.1                       amd64        Linux kernel headers for version 4.10.0 on 64 bit x86 SMP
ii  linux-image-4.10.0-26-generic                               4.10.0-26.30~16.04.1                       amd64        Linux kernel image for version 4.10.0 on 64 bit x86 SMP
ii  linux-image-extra-4.10.0-26-generic                         4.10.0-26.30~16.04.1                       amd64        Linux kernel extra modules for version 4.10.0 on 64 bit x86 SMP
               $ dpkg -l | grep linux-image
ii  linux-image-4.4.0-53-generic                                4.4.0-53.74                                amd64        Linux kernel image for version 4.4.0 on 64 bit x86 SMP
ii  linux-image-extra-4.4.0-53-generic                          4.4.0-53.74                                amd64        Linux kernel extra modules for version 4.4.0 on 64 bit x86 SMP
           $ inxi -Fxz
System:    Host: trankondur Kernel: 4.10.0-26-generic x86_64 (64 bit gcc: 5.4.0)
           Desktop: MATE 1.18.0 (Gtk 3.18.9-1ubuntu3.3)
           Distro: Linux Mint 18.2 Sonya
Machine:   System: LENOVO (portable) product: 80E5 v: Lenovo G50-80
           Mobo: LENOVO model: Lenovo G50-80 v: 31900059 WIN
           Bios: LENOVO v: B0CN69WW date: 06/20/2014
CPU:       Dual core Intel Core i5-5200U (-HT-MCP-) cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 8779
           clock speeds: max: 2201 MHz 1: 700 MHz 2: 700 MHz 3: 1200 MHz
           4: 1700 MHz
Graphics:  Card-1: Intel Broadwell-U Integrated Graphics bus-ID: 00:02.0
           Card-2: Advanced Micro Devices [AMD/ATI] Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330]
           bus-ID: 04:00.0
           Display Server: X.Org 1.18.4 drivers: ati,radeon,intel (unloaded: fbdev,vesa)
           Resolution: 1366x768@60.00hz
           GLX Renderer: Mesa DRI Intel HD Graphics 5500 (Broadwell GT2)
           GLX Version: 3.0 Mesa 17.1.4 - padoka PPA Direct Rendering: Yes
Audio:     Card-1 Intel Wildcat Point-LP High Definition Audio Controller
           Card-2 Intel Broadwell-U Audio Controller
           Sound: Advanced Linux Sound Architecture v: k4.10.0-26-generic
           driver: r8169 v: 2.3LK-NAPI port: 5000 bus-ID: 02:00.0
           Card-2: Realtek RTL8723BE PCIe Wireless Network Adapter
           driver: rtl8723be port: 4000 bus-ID: 03:00.0
Drives:    HDD Total Size: 500.1GB (11.7% used)
           ID-1: /dev/sda model: ST500LM000 size: 500.1GB
Partition: ID-1: / size: 118G used: 48G (43%) fs: ext4 dev: /dev/sda1
           ID-2: swap-1 size: 8.50GB used: 0.00GB (0%) fs: swap dev: /dev/sda5
Sensors:   System Temperatures: cpu: 47.0C mobo: N/A gpu: N/A
Info:      Processes: 206 Uptime: 32 min Memory: 1399.2/7901.7MB
           Init: systemd runlevel: 5 Gcc sys: 5.4.0           Client: Shell (bash 4.3.481) inxi: 2.2.35
« Son Düzenleme: 10 Temmuz 2017, 18:11:06 Gönderen: topal karga »
Ynt: Kworker; aşırı CPU kullanımı
« Yanıtla #1 : 10 Temmuz 2017, 13:13:18 »
Güncelleme Yöneticisideki "Linux Çekirdekleri" aracı yardımıyla çekirdğin 4.8.x serisinin en son sürümünü kurup, sistemi bununla açmayı deneyiniz. Bu şekilde durumu gözlemleyiniz. Sorun kullandığınız çekirdek sürümündeki bir hatadan kaynaklanıyor olabilr.
  • İleti: 63
Çözüldü Ynt: Kworker; aşırı CPU kullanımı
« Yanıtla #2 : 10 Temmuz 2017, 18:09:55 »
sorun çözülmüş görünüyor. teşekkürler. etiketliyorum.
