Gönderen Konu: [Çözüldü] Intel gpu kullanırken sistemi kapatamıyorum.  (Okunma sayısı 6311 defa)
Çevrimdışı samet
  • İleti: 5
inxi -SMGxx çıktısı
System:    Host: altunsoy Kernel: 4.8.0-53-generic x86_64 (64 bit gcc: 5.4.0)
           Desktop: Cinnamon 3.4.3 (Gtk 3.18.9-1ubuntu3.3) dm: lightdm
           Distro: Linux Mint 18.2 Sonya
Machine:   System: MONSTER (portable) product: ABRA A5 V10.2
           Mobo: MONSTER model: ABRA A5 V10.2
           Bios: American Megatrends v: N.1.01 date: 01/09/2017
Graphics:  Card-1: Intel Device 591b bus-ID: 00:02.0 chip-ID: 8086:591b
           Card-2: NVIDIA Device 1c8c bus-ID: 01:00.0 chip-ID: 10de:1c8c
           Display Server: X.Org 1.18.4 driver: nvidia
           Resolution: 1920x1080@60.02hz
           GLX Renderer: GeForce GTX 1050 Ti/PCIe/SSE2
           GLX Version: 4.5.0 NVIDIA 375.66 Direct Rendering: Yes
glxinfo | grep render çıktısı
OpenGL renderer string: GeForce GTX 1050 Ti/PCIe/SSE2
    GL_NVX_conditional_render, GL_NVX_gpu_memory_info, GL_NVX_nvenc_interop,
    GL_NV_compute_program5, GL_NV_conditional_render,
    GL_NV_path_rendering_shared_edge, GL_NV_pixel_data_range,
    GL_NV_shader_thread_shuffle, GL_NV_stereo_view_rendering,
    GL_EXT_protected_textures, GL_EXT_raster_multisample, GL_EXT_render_snorm,
    GL_NV_blend_equation_advanced_coherent, GL_NV_conditional_render,
    GL_NV_path_rendering_shared_edge, GL_NV_pixel_buffer_object,
lspci | egrep 'VGA|3D|Display' çıktısı
00:02.0 VGA compatible controller: Intel Corporation Device 591b (rev 04)
01:00.0 VGA compatible controller: NVIDIA Corporation Device 1c8c (rev a1)
xrandr çıktısı
eDP-1-1 connected primary 1920x1080+0+0 344mm x 194mm
   1920x1080     60.02*+  59.93
   1680x1050     59.95    59.88
   1600x1024     60.17
   1400x1050     59.98
   1280x1024     60.02
   1440x900      59.89
   1280x960      60.00
   1360x768      59.80    59.96
   1152x864      60.00
   1024x768      60.04    60.00
   960x720       60.00
   928x696       60.05
   896x672       60.01
   960x600       60.00
   960x540       59.99
   840x525       60.01    59.88
   800x512       60.17
   700x525       59.98
   640x512       60.02
   720x450       59.89
   640x480       60.00    59.94
   680x384       59.80    59.96
   576x432       60.06
   512x384       60.00
   400x300       60.32    56.34
   320x240       60.05
cat /etc/X11/xorg.conf çıktısı
Section "ServerLayout"
    Identifier "layout"
    Screen 0 "nvidia"
    Inactive "intel"
    Identifier "intel"
    Driver "modesetting"
    BusID "PCI:0@0:2:0"
    Option "AccelMethod" "None"
Section "Screen"
    Identifier "intel"
    Device "intel"
    Identifier "nvidia"
    Driver "nvidia"
    BusID "PCI:1@0:0:0"
Section "Screen"
    Identifier "nvidia"
    Device "nvidia"
dpkg -l | egrep 'nvidia|bumblebee|primus|prime|virtualgl|fglrx' çıktısı
ii  nvidia-375                                  375.66-0ubuntu0.16.04.1                                 amd64        NVIDIA binary driver - version 375.66
ii  nvidia-opencl-icd-375                       375.66-0ubuntu0.16.04.1                                 amd64        NVIDIA OpenCL ICD
ii  nvidia-prime                                0.8.2linuxmint1                                         amd64        Tools to enable NVIDIA's Prime
ii  nvidia-prime-applet                         1.0.6                                                   all          An applet for NVIDIA Prime
ii  nvidia-settings                             361.42-0ubuntu1                                         amd64        Tool for configuring the NVIDIA graphics driver
Linux Mint'i sistemime kurduktan sonra sürücü yöneticisinden önerilen nvidia sürücüsünü seçtim. Değişiklikleri uyguladım. Sistemi yeniden başlatınca sağ alt köşede nvidia simgesi belirdi. Daha düşük güç tüketimi için simgeden ayarlara girdim. Nvidia primes sekmesinden inteli seçtim.
Sorun şu ki sistem nvidia kullanırken sorunsuz bir şekilde çalışıyor. Ama intel gpu kullanırken bilgisayarı kapatamıyorum. Siyah ekran geliyor ve sol üst köşede '_' işareti beliriyor ve öylece donuyor. Güç düğmesinden kapatmak zorunda kalıyorum. Yeniden başlatamıyorum, oturumdan çıkış yapamıyorum.
Aşağıdaki kodu yazdığımda bile sistem donuyor.
lspci | egrep 'VGA|3D|Display'Sistem bilgisini görüntüleyemiyorum.
Bu saydığım şeyler sistemin donmasıyla sonuçlanıyor hiç bir şey yapamıyorum mecburen güç düğmesine basılı tutarak bilgisayarı kapatıyorum.
Ayrıyeten bilgisayarımda Windows 10 yüklü ve Windows dayken hiçbir sorun yaşamıyorum bununla ilgili.
« Son Düzenleme: 23 Eylül 2017, 17:34:00 Gönderen: samet »
Ynt: Intel gpu kullanırken sistemi kapatamıyorum.
« Yanıtla #1 : 14 Eylül 2017, 21:10:07 »
Öncelikle sistemnizi aşağıdaki şekilde güncelleyiniz.
Ayrıca sisteminizi aşağıdaki şekilde güncellemeyi deneyebilirsiniz.
Güncelleme Yöneticisi => Düzenle menüsü => Tercihler => Seviyeler kısmından 4. seviyeye kadar güncellemeleri işaretleyiniz. Ardından "Yenile" düğmesine tıklayıp paket bilgisi önbelleğini güncelledikten sonra, görünen tüm güncellemeleri seçiniz ve "Güncellemeleri Kur" düğmesine tıklayarak sisteminizi güncelleyiniz. Sonrasında isterseniz 4. seviye güncellemeleri pasifleştirebilirsiniz.
Güncelleme Yöneticisi => Görünüm menüsü => "Linux çekirdekleri" aracı yardımıyla 4.10.x serisi çekirdeğin son sürümünü kurunuz.
sudo apt-get install bumblebee nvidia-381 nvidia-settings
Güncellemeler sonrası sistemi yeniden başlatıp durumu gözlemleyiniz.
Aşağıdaki şekilde Nvidia sürücüsünün güncel sürümünü kurunuz.
Çevrimdışı samet
  • İleti: 5
« Yanıtla #2 : 14 Eylül 2017, 23:09:51 »
Dediklerinizi yaptım. Önce 4.seviye güncelleştirmeler dahil olmak üzere güncelleme yaptım. Ardıdan kernel güncelleyecektim ama güncel olduğunu gördüm. Nvidia güncelledim ve yeniden başlattım sorunsuzdu. Prime settings kısmından inteli seçtim sonra bilgisayarı kapadım. Tekrar açmaya çalıştım. Grubtan linux minti seçtim. Ortada linux mint simgesi ve yeşil noktalar çıktı. Ordan sonra siyah ekran geldi ve sistem dondu devam etmiyor. Sol üstte '_' işareti var. Güç düğmesinden kapadım açmaya tekrar çalıştım yine dondu.
Edit: Güvenli moddan başlattım
 Güncelleme yöneticisinde 4.seviye nvidia güncellemesi var.
 İsim:nvidia-settings   Yeni sürüm:384.69-0ubuntu0~gpu16.04.1
Bu güncelleştirmeyi yapmalı mıyım?
« Son Düzenleme: 14 Eylül 2017, 23:22:31 Gönderen: samet »
« Yanıtla #3 : 15 Eylül 2017, 08:59:11 »
Güncellemeyi yapabilirsiniz, ama öncelikle aşağıdaki komutla kuruduğunuz sürücüleri kaldırıp,
sudo apt-get purge nvidia* bbswitch*
ardından sistemi yeniden başlatınız ve aşağıdaki komutla Nvidia sürücüsünü yeniden kurmayı deneyiniz.
sudo apt-get install nvidia-381 nvidia-settings nvidia-prime
ardından sistemi yeniden başlatınız.
Sorun devam ederse, Nvidia GPU'dan Intel GPU'ya geçiş için aşağıdaki komutu uçbirimde çalıştırın ve çıktısını paylaşın.
sudo prime-select intel
Çevrimdışı samet
  • İleti: 5
« Yanıtla #4 : 15 Eylül 2017, 10:24:16 »
Güvenli modda sürücüleri kaldırdım. Yeniden başlattım. Oturum açma ekranı geldi şifremi girdim. Siyah ekran geldi ortada fare imleci vardı. İmleci oynatamadım. Dondu sistem. Düğmeden bilgisayarı kapatıp güvenli modda girdim. Nvidia sürücülerini yeniden kurup sistemi yeniden başlattım.  Sorunsuz girdi. Nvidia gpu kullanırken bilgisayarda sorun olmuyor. Ardından
sudo prime-select intel komutunu girdim.
Şu çıktıyla karşılaştım.
Info: the current GL alternatives in use are: ['nvidia-381', 'nvidia-381']
Info: the current EGL alternatives in use are: ['nvidia-381', 'nvidia-381']
Info: selecting nvidia-381-prime for the intel profile
update-alternatives: /etc/ld.so.conf.d/x86_64-linux-gnu_GL.conf (x86_64-linux-gnu_gl_conf) alternatifini sağlaması için /usr/lib/nvidia-381-prime/ld.so.conf elle ayarlanmış kipte kullanılıyor
update-alternatives: /etc/ld.so.conf.d/x86_64-linux-gnu_EGL.conf (x86_64-linux-gnu_egl_conf) alternatifini sağlaması için /usr/lib/nvidia-381-prime/ld.so.conf elle ayarlanmış kipte kullanılıyor
update-alternatives: /etc/ld.so.conf.d/i386-linux-gnu_GL.conf (i386-linux-gnu_gl_conf) alternatifini sağlaması için /usr/lib/nvidia-381-prime/alt_ld.so.conf elle ayarlanmış kipte kullanılıyor
update-alternatives: /etc/ld.so.conf.d/i386-linux-gnu_EGL.conf (i386-linux-gnu_egl_conf) alternatifini sağlaması için /usr/lib/nvidia-381-prime/alt_ld.so.conf elle ayarlanmış kipte kullanılıyor
Ardından sistemi yeniden başlattım. Açılırken önceden olduğu gibi Mint logosu ve yeşil noktalar geldi. Ardından siyah ekran geldi ve başka bir şey olmadı. Bilgisayarı tekrar düğmeden kapadım.
« Yanıtla #5 : 15 Eylül 2017, 11:56:15 »
Geçiş için buradaki düzenlenmiş prime-select betiği denenebilir. Yüklemek için aşağıdaki komutları kullanabilirsiniz.
cd /usr/bin
sudo mv prime-select prime-select.yedekdosya
sudo wget --no-check-certificate https://raw.githubusercontent.com/C11235/nvidia-prime-bugfix/master/prime-select
sudo chmod 755 prime-select
Çevrimdışı samet
  • İleti: 5
« Yanıtla #6 : 18 Eylül 2017, 19:43:33 »
Uzun süre geri dönemedim lütfen kusura bakmayın.
Komutları sırasıyla girdim. Ama bir şey olmadı sanırım ben eksik yaptım. Tekrar Linux Mint kurdum. Güncelleştirmeleri yaptım.
sudo add-apt-repository ppa:graphics-drivers şöyle diyerek kaynak ekledim ve sürücü yöneticisinden nvidia-384 ü seçtim. Ekran kartını intel olarak değiştirince tekrar donma sorunları oluyor.
Ve şurada benim sorunuma benzer bir sorun ve soruna cevap gördüm. Adımlar işe yarayabilir düşüncesiyle denemek istedim. Ama 8. adımda ne yapmam gerekeni anlayamadım. Ubuntu için bahsetmiş ama Linux Mint içinde işe yarar diye düşündüm. Bu alanda bilgim yok. Lütfen bilgisizliğimi mazur görün. Öğrenmeye çalışıyorum.
Çevrimdışı samet
  • İleti: 5
« Yanıtla #7 : 23 Eylül 2017, 17:33:32 »
Sorunum çözüldü. Artık intel gpu ve nvidia gpu yu sıkıntısız bir şekilde kullanabiliyorum.
Yaptığım şey ise aşağıdaki kodu grubcustomizer programını kullanarak kernel parametresi olarak eklemek oldu ve sorun çözüldü.
acpi_osi=! acpi_osi="Windows 2009"
Yararlandığım site
Ynt: [Çözüldü] Intel gpu kullanırken sistemi kapatamıyorum.
« Yanıtla #8 : 23 Eylül 2017, 21:04:17 »
[member=5124]samet[/member] geri dönüş ve bilgilendirme için teşekkür ederiz.
