Gönderen Konu: [Çözüldü] Projeksiyona görüntü aktarılmıyor  (Okunma sayısı 10676 defa)
Projeksiyona görüntü yansıtamıyorum. Ekran ayarlarımda ekrana yansıt seçeneği pasifte duruyor.
Çıktı bilgileri aşağıdaki gibidir.
[/code]
inxi -SMGxx
System:    Host: kas Kernel: 4.4.0-53-generic x86_64 (64 bit gcc: 5.4.0)
           Desktop: Cinnamon 3.2.7 (Gtk 3.18.9-1ubuntu3.3) dm: mdm
Machine:   System: Dell (portable) product: Inspiron 5423 Chassis: type: 8
           Mobo: Dell model: 071TGX v: A05 Bios: Dell v: A05 date: 09/04/2012
Graphics:  Card: Intel 2nd Generation Core Processor Family Integrated Graphics Controller
           bus-ID: 00:02.0 chip-ID: 8086:0116
           Resolution: 1366x768@60.04hz
LVDS1 connected primary 1366x768+0+0 (normal left inverted right x axis y axis) 309mm x 173mm
   1366x768      60.04*+  40.03
   1360x768      59.80    59.96
   1280x720      60.00
   1024x768      60.00
   1024x576      60.00
   960x540       60.00
   800x600       60.32    56.25
   864x486       60.00
   640x480       59.94
   720x405       60.00
   680x384       60.00
   640x360       60.00
sudo lshw -C display
  *-display
       açıklama: VGA compatible controller
       ürün: 2nd Generation Core Processor Family Integrated Graphics Controller
       üretici: Intel Corporation
       physical id: 2
       bus info: pci@0000:00:02.0
       sürüm: 09
       genişlik: 64 bits
       saat: 33MHz
       kapasiteler: msi pm vga_controller bus_master cap_list rom
       yapılandırma: driver=i915 latency=0
       kaynaklar: irq:26 bellek:f7800000-f7bfffff bellek:e0000000-efffffff ioport:f000(boyut=64
lsusb
Bus 001 Device 005: ID 1bcf:2982 Sunplus Innovation Technology Inc.
Bus 001 Device 009: ID 0cf3:e004 Atheros Communications, Inc.
Bus 001 Device 003: ID 0bda:0129 Realtek Semiconductor Corp. RTS5129 Card Reader Controller
Bus 003 Device 002: ID 09da:054f A4Tech Co., Ltd.
lspci
00:00.0 Host bridge: Intel Corporation 2nd Generation Core Processor Family DRAM Controller (rev 09)
00:14.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB xHCI Host Controller (rev 04)
00:16.0 Communication controller: Intel Corporation 7 Series/C210 Series Chipset Family MEI Controller #1 (rev 04)
00:1a.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #2 (rev 04)
00:1b.0 Audio device: Intel Corporation 7 Series/C210 Series Chipset Family High Definition Audio Controller (rev 04)
00:1c.0 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 1 (rev c4)
00:1c.3 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 4 (rev c4)
00:1c.5 PCI bridge: Intel Corporation 7 Series/C210 Series Chipset Family PCI Express Root Port 6 (rev c4)
00:1d.0 USB controller: Intel Corporation 7 Series/C210 Series Chipset Family USB Enhanced Host Controller #1 (rev 04)
00:1f.0 ISA bridge: Intel Corporation HM77 Express Chipset LPC Controller (rev 04)
00:1f.2 SATA controller: Intel Corporation 7 Series Chipset Family 6-port SATA Controller [AHCI mode] (rev 04)
00:1f.3 SMBus: Intel Corporation 7 Series/C210 Series Chipset Family SMBus Controller (rev 04)
07:00.0 Network controller: Qualcomm Atheros AR9485 Wireless Network Adapter (rev 01)
09:00.0 Ethernet controller: Qualcomm Atheros AR8162 Fast Ethernet (rev 10)
« Son Düzenleme: 20 Ekim 2017, 16:45:58 Gönderen: mehmethanifi »
Ynt: Projeksiyona görüntü aktarılmıyor
« Yanıtla #2 : 19 Ekim 2017, 12:43:08 »
Denedim hocam. üstte, ekran ayarlarında ekrana yansıt seçeneği pasif duruyor şeklinde belirtmiştim :)
« Son Düzenleme: 19 Ekim 2017, 12:47:18 Gönderen: mehmethanifi »
« Yanıtla #3 : 19 Ekim 2017, 12:49:14 »
xrandr komutunun çıktısında projeksiyon cihazı görünmüyor. Algıla düğmesine tıklayıp aşağıdaki komutların çıktılarını yeniden paylaşınız.
inxi -Gxx
« Yanıtla #4 : 19 Ekim 2017, 12:55:07 »
inxi -Gxx
   1280x720      60.00
   1024x768      60.00
   1024x576      60.00
   960x540       60.00
   800x600       60.32    56.25
   864x486       60.00
   640x480       59.94
   720x405       60.00
   680x384       60.00
   640x360       60.00
« Yanıtla #5 : 19 Ekim 2017, 12:57:48 »
4. seviye güncellemeleri yapıp,  4.4.x seri çekirdeğin son sürümünü kurmayı dener misiniz? Sorun çözülmezse 4.10.x seri çekirdeğin son sürümü kurmayı dneyebilirsiniz. Güncellemeler sonrası sistemi yeniden başlamanız gerekebilir. Şu an ki durumda projeksiyon cihazının algılanmadığı anlaşılıyor.
« Yanıtla #6 : 19 Ekim 2017, 13:00:11 »
Hemen deniyorum hocam. Bu arada sadece projeksiyona değil ikinci bir monitöre de görüntüyü yansıtmıyor hocam.
« Yanıtla #7 : 19 Ekim 2017, 13:06:24 »
Çekirdek ya da X sunucusu ile ilgili bir bug olabilir, büyük ihtimalle güncellemelerle çözülmüştür. Başka aygıtlarda durum nedir, örneğin AMD/ATI ya da Nvidia GPU olan başka aygıtları denediniz mi?
« Yanıtla #8 : 19 Ekim 2017, 13:07:49 »
Diğer cihazlarda sorun yok hocam çok rahat yansıma yaptırabiliyoruz.
Hocam çekirdek güncellemelerini yaptım. Bilgisayarı yeniden başlattım. Ekran yansıtmayı yapmadı.
System:    Host: kas Kernel: 4.10.0-37-generic x86_64 (64 bit gcc: 5.4.0
« Son Düzenleme: 19 Ekim 2017, 13:17:14 Gönderen: mehmethanifi »
« Yanıtla #9 : 19 Ekim 2017, 13:40:06 »
Projeksiyon VGA çıkışına mı takılıyor?
4. seviyedeki Xorg ve Mesa sürücüsü güncellemelerini de yaptınız mı?
« Yanıtla #10 : 19 Ekim 2017, 13:58:59 »
Bilgisayardan hdmi vga dönüştürü bir aparat ile vga bağlantısı olan bir projeksiyona bağlanıyor.
Evet Xorg ve Mesa sürücüsü güncellemelerini yaptık.
« Yanıtla #11 : 20 Ekim 2017, 14:27:32 »
Projeksiyon cihazı takılı olduğu halde sistemi başlatınca durum ne oluyor? Sistemi bu şekilde başlatıp aşağıdaki komutların çıktılarını paylaşınız.
cat /var/log/Xorg.0.log
Depodan Arandr uygulamasını kurup bununla çıkış aygıtını etkinleştirmek denenebilir.
Aşağıdaki bağlantıyı yardımcı olabilir diye ekleyelim.
http://blog.sunix.org/articles/howto/2015/09/20/Fix-xps-display-vga-screen.html
« Son Düzenleme: 20 Ekim 2017, 14:33:33 Gönderen: Butterfly »
« Yanıtla #12 : 20 Ekim 2017, 15:46:05 »
LVDS1 connected 1366x768+0+0 (normal left inverted right x axis y axis) 309mm x 173mm
   1280x720      60.00
   1024x768      60.00
   1024x576      60.00
   960x540       60.00
   800x600       60.32    56.25
   864x486       60.00
   640x480       59.94
   720x405       60.00
   680x384       60.00
   640x360       60.00
   1360x768      59.80
https://paste2.org/LH7Kbpdt
Çıkış aygıtlarını etkinleştirebileceğim yeri bu ekrandan bulamadım.
« Son Düzenleme: 20 Ekim 2017, 15:55:02 Gönderen: mehmethanifi »
« Yanıtla #13 : 20 Ekim 2017, 16:00:05 »
   1360x768      59.80
DP1 arayüzünde çözünürlük görünüyor, bağlantıdaki öneriyi mi denediniz?
« Son Düzenleme: 20 Ekim 2017, 16:02:12 Gönderen: mehmethanifi »
« Yanıtla #14 : 20 Ekim 2017, 16:02:28 »
az önce bu şekilde değiştirdim.
xrandr --output LVDS1 --mode 1280x720
Screen 0: minimum 8 x 8, current 1280 x 720, maximum 32767 x 32767
LVDS1 connected primary 1280x720+0+0 (normal left inverted right x axis y axis) 309mm x 173mm
   1366x768      60.04 +  40.03
   1280x720      60.00*
   1024x768      60.00
   1024x576      60.00
   960x540       60.00
   800x600       60.32    56.25
   864x486       60.00
   640x480       59.94
   720x405       60.00
   680x384       60.00
   640x360       60.00
   1360x768      59.80
   1280x720      60.00
Bağlantıdaki öneriyi uyguladım. Aktarım olmadı.
