Gönderen Konu: [Çözüldü] grub2 onarim hatasi  (Okunma sayısı 2572 defa)
Çevrimdışı ramazan45
  • İleti: 11
  • Dağıtım: Pardus 19.2
  • Masaüstü Ortamı: Gnome
  • Grafik Kartı: Mx110
  • İşlemci: İ5 8250u
« : 31 Ekim 2017, 17:18:28 »
windows 10 uzerinde Aomei Partition prgrami ile MBR olan diski GPT ye cevirdim windows sorunsuz acildi ancak mint e giris yapamadim live boot ile grubu yeniden yuklemeyi denedim ama yukleyemedim soyle bir cikti aldim
mint[member=37]mint[/member] ~ $ sudo mount /dev/sda3 /mnt
mount: /dev/sda3 is already mounted or /mnt busy
       /dev/sda3 is already mounted on /mnt
mint[member=37]mint[/member] ~ $ sudo mount --bind /dev /mnt/dev
mint[member=37]mint[/member] ~ $ sudo chroot /mnt
root[member=37]mint[/member] / # grub-install /dev/sda
Installing for i386-pc platform.
/proc/devices: fopen failed: No such file or directory
device node not found
grub-install.real: warning: this GPT partition label contains no BIOS Boot Partition; embedding won't be possible.
grub-install.real: warning: Embedding is not possible.  GRUB can only be installed in this setup by using blocklists.  However, blocklists are UNRELIABLE and their use is discouraged..
grub-install.real: error: will not proceed with blocklists.
soyle bir cikti daha aldim
mint[member=37]mint[/member] ~ $ sudo -s mkdir /media/linux
mint[member=37]mint[/member] ~ $ sudo -s mount /dev/sda3 /media/linux/
mint[member=37]mint[/member] ~ $ sudo -s [ -d /media/linux/boot/efi ] && echo ' ' || mkdir /media/linux/boot/efi
mint[member=37]mint[/member] ~ $ sudo -s mount /dev/sda1 /media/linux/boot/efi
mint[member=37]mint[/member] ~ $ sudo -s mount -o bind /dev/ /media/linux/dev/
mint[member=37]mint[/member] ~ $ sudo -s mount -o bind /sys/ /media/linux/sys/
mint[member=37]mint[/member] ~ $ sudo -s mount -o bind /proc/ /media/linux/proc/
mint[member=37]mint[/member] ~ $ sudo -s chroot /media/linux
ayni bir degisen olmadi
yardimlarinizi bekliyorum tesekkurler :)
« Son Düzenleme: 01 Kasım 2017, 07:41:13 Gönderen: ramazan45 »
Ynt: grub2 onarim hatasi
« Yanıtla #1 : 31 Ekim 2017, 22:10:11 »
Grub'u Boot Repair ile yeniden kurmayı deneyebilirsiniz.
  • İleti: 11
  • İşlemci: İ5 8250u
« Yanıtla #2 : 01 Kasım 2017, 07:40:33 »
Teşekkürler. Daha önc boot rapair ile onarım anlatımda ki gibi uygulamıştım ancak uçbirime kopyala yapıştırları yapmayı fark edememişim o yüzden hata oluştu şimdi dikkatli uygulayınca sorunum çözüldü tesekkür ederim.
