Gönderen Konu: [Çözüldü] AMD Radeon R7 M260/M265  (Okunma sayısı 3767 defa)
Çevrimdışı timur-75
  • İleti: 93
« : 06 Ocak 2018, 13:24:32 »
Merhaba, yeni aldığım dizüstü bilgisayarımda başlıkta da ismi yazan harici bir gpu var. Ancak ek sürücülerde İntel microde sürücüsü dışında bir şey yok. Manuel olarakta nasıl yükleyeceğimi bilmiyorum. Yardımcı olursanız sevinirim.
timur@tekir:~$ inxi -b
System:    Host: tekir Kernel: 4.10.0-42-generic x86_64 (64 bit) Desktop: Gnome
           Distro: elementary 0.4.1 loki
Machine:   System: HP product: HP Laptop 15-bs0xx v: Type1ProductConfigId
           Mobo: HP model: 832B v: 23.45 Bios: Insyde v: F.31 date: 11/01/2017
CPU:       Dual core Intel Core i5-7200U (-HT-MCP-) speed/max: 3099/3100 MHz
Graphics:  Card-1: Intel Device 5916
           Card-2: Advanced Micro Devices [AMD/ATI] Topaz XT [Radeon R7 M260/M265]
           Display Server: X.Org 1.19.5 drivers: ati,amdgpu (unloaded: fbdev,vesa)
           Resolution: 1366x768@60.02hz
           GLX Renderer: Mesa DRI Intel HD Graphics 620 (Kaby Lake GT2)
           GLX Version: 3.0 Mesa 17.2.4
           driver: r8169
           Card-2: Intel Device 24fb driver: iwlwifi
Drives:    HDD Total Size: 256.1GB (6.2% used)
Info:      Processes: 207 Uptime: 14 min Memory: 1506.1/7899.0MB
           Client: Shell (bash) inxi: 2.2.35
timur@tekir:~$ inxi -SMGxx
System:    Host: tekir Kernel: 4.10.0-42-generic x86_64 (64 bit gcc: 5.4.0)
           Desktop: Gnome  (Gtk 3.18.9-1ubuntu3.3) dm: lightdm
           Chassis: type: 10
Graphics:  Card-1: Intel Device 5916 bus-ID: 00:02.0 chip-ID: 8086:5916
           bus-ID: 01:00.0 chip-ID: 1002:6900
           GLX Version: 3.0 Mesa 17.2.4 Direct Rendering: Yes
timur@tekir:~$ glxinfo | grep render
OpenGL renderer string: Mesa DRI Intel(R) HD Graphics 620 (Kaby Lake GT2)
timur@tekir:~$ lspci | egrep 'VGA|3D|Display'
00:02.0 VGA compatible controller: Intel Corporation Device 5916 (rev 02)
01:00.0 Display controller: Advanced Micro Devices, Inc. [AMD/ATI] Topaz XT [Radeon R7 M260/M265] (rev 83)
timur@tekir:~$ xrandr
eDP-1 connected primary 1366x768+0+0 (normal left inverted right x axis y axis) 344mm x 193mm
   1366x768      60.02*+  40.01
   1360x768      59.80    59.96
   1024x768      60.04    60.00
   960x720       60.00
   928x696       60.05
   896x672       60.01
   960x600       60.00
   960x540       59.99
   840x525       60.01    59.88
   800x512       60.17
   700x525       59.98
   640x512       60.02
   720x450       59.89
   640x480       60.00    59.94
   680x384       59.80    59.96
   576x432       60.06
   512x384       60.00
   400x300       60.32    56.34
   320x240       60.05
timur@tekir:~$ cat /etc/X11/xorg.conf
komutunun bir çıktısı ise yok
« Son Düzenleme: 06 Ocak 2018, 15:02:21 Gönderen: timur-75 »
Ynt: AMD Radeon R7 M260/M265
« Yanıtla #1 : 06 Ocak 2018, 14:01:57 »
Sürücünüz yüklü durumda.
Linux dağıtımlarında açık kaynak sürücü olan Mesa kurulu gelir , Mesa'nın içeriğinde Intel , AMD ( radeonsi ve amdgpu )ve Nvidia (nouveau) kurulu gelir. Sistem uygun olanı kendisi seçip kullanır.
Kapalı kaynak sürücüleri sonradan kurmanız gerekir.  Eğer isterseniz.
Nvidia tarafında kapalı kaynak sürücü oyun , ekran kartı tabanlı işleme tarafında daha iyiyken ; AMD tarafında oyun için Mesa , işleme tarafında ise ( OpenCL örneğin ) kapalı kaynak sürücü daha iyi durumda.
Çevrimdışı timur-75
  • İleti: 93
« Yanıtla #2 : 06 Ocak 2018, 14:08:56 »
[member=3240]Leopard[/member] Öncelikle cevabınız için teşekkür ederim.
Steam üzerinden Euro Truck Simulator 2 ya da Hacknet, Plague Inc. gibi öyle ahım şahım donanım istemeyen oyunları oynuyorum. Bu durumda tavsiyeniz, kapalı kaynak sürücüsünden uzak durmam yönünde mi?
« Yanıtla #3 : 06 Ocak 2018, 14:50:49 »
[member=1221]timur-75[/member]
Evet , açık kaynak sürücüyü kullanmalısınız. Zira OpenGL performansı daha yüksek.
Steam'de oynayacağınız oyunların kütüphaneden başlatma seçeneğine
DRI_PRIME=1 %command%
komutunu eklerseniz oyunlar AMD kart ile açılır.  Aksi takdirde ise işlemciye entegre Intel HD ile ki onun performansı AMD karta göre düşük.
Rica ederim.
