Gönderen Konu: Bilgisayar Açılırken Ekran Çok Geç Açılıyor  (Okunma sayısı 2159 defa)
Çevrimdışı VoSToK
  • İleti: 24
  • Dağıtım: Mint 18.1
  • Masaüstü Ortamı: Cinnamoon
  • Grafik Kartı: Geforce M480
Bilgisayarı açtıktan sonra oturum şifremi giriyorum ve masaüstünün açılması 45-50 saniyeyi buluyor.
inxi -Fxz çıktısı;
System:    Host: VoSToK Kernel: 4.4.0-116-generic x86_64 (64 bit gcc: 5.4.0)
           Desktop: Cinnamon 3.2.7 (Gtk 3.18.9-1ubuntu3.3)
Machine:   Mobo: Acer model: Aspire 5742G v: V1.09
           Bios: Acer v: V1.09 date: 11/08/2010
CPU:       Dual core Intel Core i5 M 480 (-HT-MCP-) cache: 3072 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 10641
           clock speeds: max: 2667 MHz 1: 1599 MHz 2: 1733 MHz 3: 1333 MHz
           4: 1199 MHz
Graphics:  Card-1: Intel Core Processor Integrated Graphics Controller
           Card-2: NVIDIA GF108M [GeForce GT 420M] bus-ID: 01:00.0
           Resolution: 1366x768@60.04hz
           GLX Renderer: Mesa DRI Intel Ironlake Mobile
           GLX Version: 2.1 Mesa 11.2.0 Direct Rendering: Yes
Audio:     Card Intel 5 Series/3400 Series High Definition Audio
           Sound: Advanced Linux Sound Architecture v: k4.4.0-116-generic
Network:   Card-1: Broadcom NetLink BCM57780 Gigabit Ethernet PCIe
           driver: tg3 v: 3.137 bus-ID: 02:00.0
           Card-2: Qualcomm Atheros AR9287 Wireless Network Adapter (PCI-Express)
           driver: ath9k bus-ID: 03:00.0
Drives:    HDD Total Size: 640.1GB (4.6% used)
           ID-1: /dev/sda model: WDC_WD6400BEVT size: 640.1GB
Partition: ID-1: / size: 100G used: 28G (30%) fs: ext4 dev: /dev/sda5
Sensors:   System Temperatures: cpu: 47.0C mobo: N/A
Info:      Processes: 191 Uptime: 12 min Memory: 1486.3/3625.9MB
dmesg çıktısı;
https://paste2.org/PeF879jm
systemd-analyze time
Startup finished in 8.479s (kernel) + 48.240s (userspace) = 56.720s
19.646s dev-sda5.device
         12.939s ModemManager.service
         12.422s networking.service
         10.526s NetworkManager-wait-online.service
          9.859s accounts-daemon.service
          8.659s apt-daily.service
          8.525s ntp.service
          8.307s ondemand.service
          8.045s thermald.service
          7.791s speech-dispatcher.service
          7.633s systemd-rfkill.service
          7.354s lvm2-monitor.service
          7.346s console-kit-log-system-start.service
          7.140s nmbd.service
          6.828s pppd-dns.service
          6.471s samba-ad-dc.service
          4.615s systemd-udevd.service
          4.164s NetworkManager.service
          2.824s loadcpufreq.service
          2.180s systemd-tmpfiles-setup.service
          2.121s systemd-tmpfiles-setup-dev.service
          1.938s upower.service
          1.826s irqbalance.service
          1.765s grub-common.service
          1.659s systemd-backlight@backlight:acpi_video0.service
          1.576s systemd-logind.service
          1.550s systemd-update-utmp.service
          1.482s keyboard-setup.service
          1.434s virtualbox-guest-utils.service
          1.431s avahi-daemon.service
          1.428s console-setup.service
          1.372s rsyslog.service
          1.307s systemd-udev-trigger.service
          1.207s systemd-modules-load.service
          1.187s binfmt-support.service
          1.131s systemd-journald.service
          1.089s polkitd.service
           802ms virtualbox.service
           736ms systemd-backlight@backlight:intel_backlight.service
           691ms apt-daily-upgrade.service
           587ms plymouth-start.service
           561ms colord.service
           540ms hddtemp.service
           526ms rc-local.service
           515ms plymouth-read-write.service
           514ms wpa_supplicant.service
           506ms systemd-sysctl.service
           490ms ufw.service
           423ms smbd.service
           420ms dev-mqueue.mount
           419ms dev-hugepages.mount
           401ms kmod-static-nodes.service
           377ms lm-sensors.service
           342ms iio-sensor-proxy.service
           300ms systemd-journal-flush.service
           291ms udisks2.service
           284ms systemd-remount-fs.service
           252ms sys-kernel-debug.mount
           251ms proc-sys-fs-binfmt_misc.mount
           235ms systemd-random-seed.service
           189ms resolvconf.service
           187ms user@1000.service
           177ms alsa-restore.service
           154ms cpufrequtils.service
           124ms dns-clean.service
           113ms console-kit-daemon.service
            90ms plymouth-quit.service
            90ms plymouth-quit-wait.service
            46ms setvtrgb.service
            36ms systemd-user-sessions.service
            31ms openvpn.service
            26ms rtkit-daemon.service
             5ms systemd-update-utmp-runlevel.service
             4ms ureadahead-stop.service
             3ms sys-fs-fuse-connections.mount
journalctl --no-pager -b -p3
-- Logs begin at Çrş 2018-03-14 21:11:10 +03, end at Çrş 2018-03-14 21:23:10 +03. --
Mar 14 21:11:29 VoSToK systemd-udevd[934]: failed to execute '/usr/bin/nvidia-smi' '/usr/bin/nvidia-smi': No such file or directory
Mar 14 21:11:30 VoSToK ntpdate[949]: name server cannot be used: Temporary failure in name resolution (-3)
Mar 14 21:11:35 VoSToK NetworkManager[871]: nm_device_get_device_type: assertion 'NM_IS_DEVICE (self)' failed
Mar 14 21:11:36 VoSToK wpa_supplicant[1066]: dbus: wpa_dbus_get_object_properties: failed to get object properties: (none) none
Mar 14 21:11:36 VoSToK wpa_supplicant[1066]: dbus: Failed to construct signal
Mar 14 21:12:06 VoSToK mdm[1396]: PAM unable to dlopen(pam_kwallet.so): /lib/security/pam_kwallet.so: paylaşımlı nesne dosyası açılamıyor: Böyle bir dosya ya da dizin yok
Mar 14 21:12:06 VoSToK mdm[1396]: PAM adding faulty module: pam_kwallet.so
Mar 14 21:12:10 VoSToK mdm[1396]: GLib-CRITICAL: g_key_file_get_string: assertion 'key_file != NULL' failed
Mar 14 21:12:10 VoSToK mdm[1396]: GLib-CRITICAL: g_key_file_free: assertion 'key_file != NULL' failed
Mar 14 21:12:42 VoSToK pulseaudio[2170]: [pulseaudio] bluez5-util.c: GetManagedObjects() failed: org.freedesktop.DBus.Error.NoReply: Did not receive a reply. Possible causes include: the remote application did not send a reply, the message bus security policy blocked the reply, the reply timeout expired, or the network connection was broken.
Mar 14 21:23:10 VoSToK sudo[4668]:   vostok : a password is required ; TTY=pts/0 ; PWD=/home/vostok ; USER=root ; COMMAND=/usr/sbin/hddtemp -nq -u C /dev/sda
systemctl --no-pager --state=failed
Ynt: Bilgisayar Açılırken Ekran Çok Geç Açılıyor
« Yanıtla #1 : 14 Mart 2018, 22:09:52 »
Öncelikle sisteminizi aşağıdaki şekilde güncellemeyi dener misiniz?
Güncelleme Yöneticisi => Düzenle menüsü => Tercihler => Seviyeler kısmından 4. seviyeye kadar güncellemeleri işaretleyiniz. Ardından "Yenile" düğmesine tıklayıp paket bilgisi önbelleğini güncelledikten sonra, görünen tüm güncellemeleri seçiniz ve "Güncellemeleri Kur" düğmesine tıklayarak sisteminizi güncelleyiniz. Sonrasında isterseniz 4. seviye güncellemeleri pasifleştirebilirsiniz.
Güncelleme Yöneticisi => Görünüm menüsü => "Linux çekirdekleri" aracı yardımıyla 4.13.x serisi çekirdeğin son sürümünü kurunuz.
Ardından sisteminizi yeniden başlatınız.
