Gönderen Konu: [Çözüldü] Nvidia Settings Çalışmıyor  (Okunma sayısı 3526 defa)
Çevrimdışı nefarkeder
  • İleti: 97
  • Grafik Kartı: NVIDIA GEFORCE 940MX
  • İşlemci: Intel© Core™ i7-7500U CPU @ 2.70GHz × 2
« : 16 Nisan 2018, 22:49:19 »
Merhabalar dostlar,
Durduk yere Nvidia Settings çalışmamaya başladı, hata da vermiyor sadece açılmıyor hiçbir şekilde. Bu yüzden Nvidia ile Intel ekran kartları arasında seçim yapamıyorum. Bir fikri olan varsa çok güzel olur.
inxi -SMGxx
System:    Host: writingmachine Kernel: 4.13.0-38-generic x86_64 (64 bit gcc: 5.4.0)
           Desktop: Cinnamon 3.6.7 (Gtk 3.18.9-1ubuntu3.3) dm: lightdm
Machine:   System: ASUSTeK (portable) product: UX310UQK v: 1.0
           Mobo: ASUSTeK model: UX310UQK v: 1.0
           Bios: American Megatrends v: UX310UQK.300 date: 10/03/2016
Graphics:  Card-1: Intel Device 5916 bus-ID: 00:02.0 chip-ID: 8086:5916
           Card-2: NVIDIA GM108M [GeForce 940MX]
           bus-ID: 01:00.0 chip-ID: 10de:134d
           Display Server: X.Org 1.19.5 drivers: (unloaded: fbdev,vesa)
           Resolution: 3200x1800@60.00hz
           GLX Renderer: Mesa DRI Intel HD Graphics 620 (Kaby Lake GT2)
           GLX Version: 3.0 Mesa 17.2.8 Direct Rendering: Yes
OpenGL renderer string: Mesa DRI Intel(R) HD Graphics 620 (Kaby Lake GT2)
00:02.0 VGA compatible controller: Intel Corporation Device 5916 (rev 02)
01:00.0 3D controller: NVIDIA Corporation GM108M [GeForce 940MX] (rev ff)
Screen 0: minimum 320 x 200, current 3200 x 1800, maximum 8192 x 8192
eDP-1 connected primary 3200x1800+0+0 (normal left inverted right x axis y axis) 293mm x 165mm
   3200x1800     60.00*+  48.00
   2048x1536     60.00
   1920x1440     60.00
   1856x1392     60.01
   1792x1344     60.01
   1920x1200     59.95
   1920x1080     59.93
   1600x1200     60.00
   1680x1050     59.95    59.88
   1600x1024     60.17
   1400x1050     59.98
   1280x1024     60.02
   1440x900      59.89
   1280x960      60.00
   1360x768      59.80    59.96
   1152x864      60.00
   1024x768      60.04    60.00
   960x720       60.00
   928x696       60.05
   896x672       60.01
   960x600       60.00
   960x540       59.99
   840x525       60.01    59.88
   800x512       60.17
   700x525       59.98
   640x512       60.02
   720x450       59.89
   640x480       60.00    59.94
   680x384       59.80    59.96
   576x432       60.06
   512x384       60.00
   400x300       60.32    56.34
   320x240       60.05
HDMI-2 disconnected (normal left inverted right x axis y axis)
rc  nvidia-387                                  387.34-0ubuntu0~gpu16.04.2                              amd64        NVIDIA binary driver - version 387.34
ii  nvidia-396                                  396.18-0ubuntu0~gpu16.04.2                              amd64        NVIDIA binary driver - version 396.18
rc  nvidia-opencl-icd-384                       384.90-0ubuntu0.16.04.2                                 amd64        NVIDIA OpenCL ICD
ii  nvidia-opencl-icd-396                       396.18-0ubuntu0~gpu16.04.2                              amd64        NVIDIA OpenCL ICD
ii  nvidia-prime                                0.8.2linuxmint1                                         amd64        Tools to enable NVIDIA's Prime
ii  nvidia-prime-applet                         1.0.6                                                   all          An applet for NVIDIA Prime
ii  nvidia-settings                             396.18-0ubuntu0~gpu16.04.1                              amd64        Tool for configuring the NVIDIA graphics driver
« Son Düzenleme: 19 Nisan 2018, 15:09:17 Gönderen: nefarkeder »
Ynt: Nvidia Settings Çalışmıyor
« Yanıtla #1 : 17 Nisan 2018, 11:29:39 »
Aşağıdaki komutu uçbirimde çalıştırın ve ardından sistemi yeniden başlatmayı deneyin.
sudo prime-select nvidia
  • İleti: 97
« Yanıtla #2 : 17 Nisan 2018, 16:45:50 »
Evet, bu işe yarıyor iki taraf için de. Fakat Nvidia Settings neden çalışmıyor? Uçbirim'den "nvidia-settings" yazarak çalıştırmaya çalıştığımda şu çıktıyı veriyor:
ERROR: Unable to load info from any available system
« Yanıtla #3 : 17 Nisan 2018, 21:35:54 »
Aşağıdaki komutla daha eski bir sürümü yüklemeyi dener misiniz?
sudo apt install nvidia-settings=361.42-0ubuntu1
  • İleti: 97
« Yanıtla #4 : 19 Nisan 2018, 15:09:02 »
Çok teşekkürler hocam, eski sürümü verdiğiniz komutla yükleyince çalıştı. Sanıyorum çalışmayan sürümün yerine yenisi geldiğinde tekrar yükseltmeyi denemem gerekecek, doğru mudur? Bu arada "çözüldü" olarak işaretliyorum. Tekrar aklınıza sağlık.
Ynt: [Çözüldü] Nvidia Settings Çalışmıyor
« Yanıtla #5 : 19 Nisan 2018, 15:38:43 »
Evet, sorun büyük ihtimalle daha güncel paket ile çözülecektir. Bu zamana kadar nvidia-settings paketini güncellemeyin. Dilerseniz Güncelleme Yöneticisinden gizleyebilirsiniz. Güncel sürümle sorun çözülmezse, yine eski sürümü yükleyip, Synaptic Paket Yöneticisi ( => paket menüsü => sürümü kilitle) yardımıyla sürümü güncellemeye karşı kilitleyebilirsiniz.
[okay]Sorun çözüldüğü için konu kilitlenmiştir[/okay]
