Gönderen Konu: Firefox açıldığında letgo reklamı çıkması ! Size de oluyor mu ?  (Okunma sayısı 2854 defa)
Çevrimdışı minteger
  • İleti: 381
Dikkat ! Bazı arkadaşlar özellikle yeni arkadaşlar. Aşağıda göreceksiniz ki dağıtım ismi ile kullanıcı ismi aynı.
--- Sakın ola böyle birşey yapmayın.
rosa@rosa-pc:~ > inxi -SMNnxxzSystem:    Host: rosa-pc Kernel: 3.19.0-32-generic x86_64 (64 bit gcc: 4.8.2)
           Desktop: Cinnamon 2.8.8 (Gtk 3.10.8~8+qiana) dm: mdm Distro: Linux Mint 17.3 Rosa
Machine:   Mobo: ASUSTeK model: M4A77TD PRO v: Rev X.0x Bios: American Megatrends v: 2005 date: 04/15/2010
           driver: r8169 v: 2.3LK-NAPI port: e800 bus-ID: 06:00.0 chip-ID: 10ec:8168
rosa@rosa-pc:~ > lspci -nnk | grep -iA2 net
06:00.0 Ethernet controller [0200]: Realtek Semiconductor Co., Ltd. RTL8111/8168/8411 PCI Express Gigabit Ethernet Controller [10ec:8168] (rev 03)
        Subsystem: ASUSTeK Computer Inc. M4A785TD Motherboard [1043:83a3]
        Kernel driver in use: r8169
rosa@rosa-pc:~ > lsusb
Bus 009 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 004 Device 001: ID 1d6b:0002 Linux Foundation 2.0 root hub
Bus 008 Device 001: ID 1d6b:0001 Linux Foundation 1.1 root hub
Bus 006 Device 002: ID 09da:000a A4Tech Co., Ltd. Optical Mouse Opto 510D / OP-620D
Bus 005 Device 002: ID 04e8:3268 Samsung Electronics Co., Ltd ML-1610 Mono Laser Printer
rosa@rosa-pc:~ > rfkill list
rosa@rosa-pc:~ > sudo lshw -C network
[sudo] password for rosa:
  *-network
       physical id: 0
       bus info: pci@0000:06:00.0
       logical name: eth0
       version: 03
       serial: 48:5b:39:33:b0:60
       capacity: 1Gbit/s
       width: 64 bits
       clock: 33MHz
       capabilities: pm msi pciexpress msix vpd bus_master cap_list rom ethernet physical tp mii 10bt 10bt-fd 100bt 100bt-fd 1000bt 1000bt-fd autonegotiation
       configuration: autonegotiation=on broadcast=yes driver=r8169 driverversion=2.3LK-NAPI duplex=full firmware=rtl_nic/rtl8168d-2.fw ip=192.168.1.202 latency=0 link=yes multicast=yes port=MII speed=100Mbit/s
       resources: irq:36 ioport:e800(size=256) memory:f8fff000-f8ffffff memory:f8ff8000-f8ffbfff memory:fbff0000-fbffffff
rosa@rosa-pc:~ > iwconfig | grep Power
rosa@rosa-pc:~ > lsmod
usblp                  24576  0
snd_hda_codec_hdmi     53248  4
kvm_amd                61440  0
kvm                   479232  1 kvm_amd
snd_hda_codec_via      32768  1
snd_hda_codec_generic    69632  1 snd_hda_codec_via
snd_hda_intel          36864  4 snd_hda_codec_hdmi
scsi_dh                16384  1 dm_multipath
edac_core              53248  0
snd_hda_codec         143360  5 snd_hda_codec_hdmi,snd_hda_codec_via,snd_hda_codec_generic,snd_hda_intel,snd_hda_controller
edac_mce_amd           24576  0
snd_pcm               106496  4 snd_hda_codec_hdmi,snd_hda_codec,snd_hda_intel,snd_hda_controller
i2c_piix4              24576  0
snd                    86016  17 snd_hwdep,snd_timer,snd_hda_codec_hdmi,snd_hda_codec_via,snd_pcm,snd_seq,snd_rawmidi,snd_hda_codec_generic,snd_hda_codec,snd_hda_intel,snd_seq_device
tpm_infineon           20480  0
shpchp                 40960  0
rfcomm                 69632  0
bluetooth             491520  10 bnep,rfcomm
it87                   45056  0
hwmon_vid              16384  1 it87
hid_a4tech             16384  0
hid                   110592  2 hid_a4tech,usbhid
nouveau              1368064  3
video                  20480  1 nouveau
pata_atiixp            16384  0
i2c_algo_bit           16384  1 nouveau
ttm                    94208  1 nouveau
drm_kms_helper        126976  1 nouveau
drm                   344064  6 ttm,drm_kms_helper,nouveau
wmi                    20480  2 mxm_wmi,nouveau
rosa@rosa-pc:~ >
Bazı çıktıları paylaşıtm. Ama bunlarla alakası yok tabi.
Bilgisayarı ilk kez açıldıktan sonra firefoxu ilk kez açtığımda sağ üst köşede letgo reklamı beliriyor.
Anlam veremedim. Benzer bir şey bulamadım da. Hani letgoya girsem anlarım. Ama letgoya yarım yıl kadar önce girdim ve hala girmiyorum.
Ne oluyor acaba ? Bir firefox pop-up ı değil. Daha ziyade tam ekranın köşesinde beliren linux uyarısı gibi.
Şahsınıza özel yaptığınız bir işlem sonucu olabilir. Böyle bir durum bende olmuyor. Tarayıcıyı kapatıp aşağıdaki komutla Firefox'u güvenli kipte başlatmayı deneyebilirsiniz, bu şekilde eklenti ve özel temalar etkin olmuyor.. Not: Safemode seçeneği ile başlatın, diğer seçenek (refresh) Firefox ayarlarını sıfırlar.
firefox --safe-mode
« Son Düzenleme: 01 Temmuz 2018, 14:32:29 Gönderen: Butterfly »
Çevrimdışı minteger
  • İleti: 381
firefox --safe-mode
Tamamdır bi bakalım.
Bende olmuyor.
