Gönderen Konu: Linux Mint 19'a Yükseltme Sonrası - Cinnamon masaüstü çöktü , fallback kipi  (Okunma sayısı 8192 defa)
Çevrimdışı bahadir1903
  • İleti: 14
18.3 den 19 tara ya yükselttim ama aynı hata bende de oldu. yukarıda söylenenleri yaptım çıktılar şu şekilde;
Home dizininde cinnemon dosyasının içeriği
cinnamon: error while loading shared libraries: libGL.so.1: cannot open shared object file: No such file or directory
cat ~/.cinnamon/glass.log komutunun çıktısı;
cat: /home/bahadir/.cinnamon/glass.log: No such file or directory
bahadir@bahadir ~ $ inxi -SMGxx
System:    Host: bahadir Kernel: 4.15.0-24-generic x86_64 bits: 64 gcc: 7.3.0
           Desktop: Cinnamon (Gtk 3.22.30-1ubuntu1) dm: lightdm
           Distro: Linux Mint 19 Tara
Machine:   Device: laptop System: HP product: HP Pavilion Notebook serial: N/A
           Mobo: HP model: 81FE v: 81.20 serial: N/A
           UEFI [Legacy]: American Megatrends v: F.07 date: 06/13/2016
           Chassis: type: 10 serial: N/A
Graphics:  Card-1: Advanced Micro Devices [AMD/ATI] Carrizo
           bus-ID: 00:01.0 chip-ID: 1002:9874
           Card-2: Advanced Micro Devices [AMD/ATI] Topaz XT [Radeon R7 M260/M265 / M340/M360 / M440/M445]
           bus-ID: 04:00.0 chip-ID: 1002:6900
           drivers: ati,amdgpu (unloaded: modesetting,fbdev,vesa,radeon)
           Resolution: 1920x1080@60.01hz
           OpenGL: renderer: N/A version: N/A Direct Render: N/A
bahadir@bahadir ~ $ glxinfo | grep render
glxinfo: error while loading shared libraries: libGL.so.1: cannot open shared object file: No such file or directory
bahadir@bahadir ~ $ lspci | egrep 'VGA|3D|Display'
00:01.0 VGA compatible controller: Advanced Micro Devices, Inc. [AMD/ATI] Carrizo (rev ca)
04:00.0 Display controller: Advanced Micro Devices, Inc. [AMD/ATI] Topaz XT [Radeon R7 M260/M265 / M340/M360 / M440/M445] (rev ff)
bahadir@bahadir ~ $ xrandr
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 16384 x 16384
eDP connected primary 1920x1080+0+0 344mm x 193mm
   1920x1080     60.01*+  40.00
   1680x1050     60.01
   1280x1024     60.01
   1440x900      60.01
   1280x800      60.01
   1280x720      60.01
   1024x768      60.01
   800x600       60.01
   640x480       60.01
HDMI-A-0 disconnected
bahadir@bahadir ~ $ cat /etc/X11/xorg.conf
bahadir@bahadir ~ $ dpkg -l | egrep 'nvidia|bumblebee|primus|prime|virtualgl|fglrx'
ii  libnvidia-common-390                                        390.48-0ubuntu3                             all          Shared files used by the NVIDIA libraries
ii  libnvidia-gl-390:amd64                                      390.48-0ubuntu3                             amd64        NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii  nvidia-prime-applet                                         1.0.7                                       all          An applet for NVIDIA Prime
ekran ile alakalı çıktılar böyle
« Son Düzenleme: 05 Temmuz 2018, 14:29:03 Gönderen: bahadir1903 »
[member=2278]bahadir1903[/member] , forumda benzer sorun dahi olsa, aynı başlık altında birbirinden farklı soru ve sorunlar hakkında konuşmuyoruz. Sizin sisteminizdeki sorun yükseltme sonrası olduğu için farklılık arzediyor. Bu sebeple mesaj bölünerek yeni bir konu oluşturulmuştur.
Çıktılarda Nvidia ile ilgili ilgili sürücü kurma girişimi olduğu anlaşılıyor, bu hususla ilgili ne yaptığınız hakkında daha fazla bilgi veriniz.
Sorunun şu an GPU ile ilgili 3D hızlandırmada olduğu görünüyor..
« Son Düzenleme: 05 Temmuz 2018, 15:11:21 Gönderen: Butterfly »
  • İleti: 14
uyarınız için tşk ederim. bir dahaki sefer daha dikkatli olurum.
Nvidia sürücüsü ile ilgili her hangi bir işlem yapmadım. daha önce ekran kararma sorunum vardı internetten araştırırken bir kaç komut çalıştırmıştım. o zaman yanlış bir komut çalıştırmış olabilirim.
Aşağıdaki komutla kurulu görülen paketleri kaldırıp sistemi yeniden başlatmayı deneyiniz.
sudo apt purge libnvidia*
sudo apt purge nvidia*
Sorun yukarıdaki şekilde çözülmezse bu husus hakkında (yaptığınız düzenlemelerin ne olduğu hakkında) daha fazla bilgi paylaşınız.
  • İleti: 14
Yukarıdaki komutlardan sonra şimdi pc hiç açılmıyor. Önce mint logosu geliyor sonra siyah ekran _ şeklinde kalıyor. Hiç bir işlem yapılmıyor.
Nvidia GPU ile ilgili paketlerin kaldırılmasının sizin sisteminize etki etme olasılığı çok düşük, bu paketler Nvidia sürücüsü ile ilgili ve sizin sisteminizde MAD GPU olduğu için etkinleşmiyor zaten.
Sisteme aşağıdaki şekilde kurtarma kipi ile erişebiliyor musunuz?
Grub önyükleyici menüsü => Gelişmiş seçenekler  altındaki kurtarma kipi (recovery mode) seçeneği ile sistemi başlatın. Bir süre sonra bir menü daha gelecek, burada "resume" seçeneğini seçerek devam edin.
  • İleti: 14
Login ekranı geldi. Şifreyi girince:
:unable to launch '' cinnemon-session-cinnamon'' X session - - -
"cinnemon-session-cinnemon" not found; falling back to default session.
Yazısı çıkıyor. Okay tıklayınca yine login ekranına dönüyor
CTRL+ALT+F1 tuşlarına birlikte basarak TYY uçbirimine ulaşın ve kullanıcı adı ve şifresini girip oturum açtıktan sonra aşağıdaki komutlarla eksik paketler kurmayı deneyin.
sudo apt update
sudo apt install mint-meta-cinnamon cinnamon-session cinnamon-session-common
  • İleti: 14
Şimdi Masaüstü açılıyor ama yine fallback kipinde açılıyor
Ekran kartı ile ilgili çıktıları yeniden paylaşınız, ayrıca aşağıdaki komutların çıktılarını da ekleyiniz.
dpkg -l | grep xserver-xorg
apt list --upgradable
Sistemi "Grub önyükleyici menüsü => Gelişmiş seçenekler" altındaki eski çekirdeklerden bir tanesi ile açmayı da dener misiniz?
« Son Düzenleme: 06 Temmuz 2018, 00:39:55 Gönderen: Butterfly »
  • İleti: 14
System:    Host: bahadir Kernel: 4.13.0-43-generic x86_64 bits: 64 gcc: 5.4.0
   1680x1050     60.00
   1400x1050     60.00
   1280x1024     59.95
   1440x900      59.99
   1280x960      59.99
   1280x854      59.95
   1280x800      59.96
   1280x720      59.97
   1152x768      59.95
   1024x768      59.95
   800x600       59.96
   848x480       59.94
   720x480       59.94
   640x480       59.94
bahadir@bahadir ~ $ dpkg -l | grep xserver-xorg
ii  xserver-xorg                                                1:7.7+19ubuntu7                             amd64        X.Org X server
ii  xserver-xorg-core                                           2:1.19.6-1ubuntu4                           amd64        Xorg X server - core server
ii  xserver-xorg-input-all                                      1:7.7+19ubuntu7                             amd64        X.Org X server -- input driver metapackage
ii  xserver-xorg-input-evdev                                    1:2.10.5-1ubuntu1                           amd64        X.Org X server -- evdev input driver
ii  xserver-xorg-input-libinput                                 0.27.1-1                                    amd64        X.Org X server -- libinput input driver
ii  xserver-xorg-input-synaptics                                1.9.0-1ubuntu1                              amd64        Synaptics TouchPad driver for X.Org server
ii  xserver-xorg-input-wacom                                    1:0.36.1-0ubuntu1                           amd64        X.Org X server -- Wacom input driver
ii  xserver-xorg-video-all                                      1:7.7+19ubuntu7                             amd64        X.Org X server -- output driver metapackage
ii  xserver-xorg-video-amdgpu                                   18.0.1-1                                    amd64        X.Org X server -- AMDGPU display driver
ii  xserver-xorg-video-ati                                      1:18.0.1-1                                  amd64        X.Org X server -- AMD/ATI display driver wrapper
ii  xserver-xorg-video-fbdev                                    1:0.4.4-1build6                             amd64        X.Org X server -- fbdev display driver
ii  xserver-xorg-video-intel                                    2:2.99.917+git20171229-1                    amd64        X.Org X server -- Intel i8xx, i9xx display driver
ii  xserver-xorg-video-nouveau                                  1:1.0.15-2                                  amd64        X.Org X server -- Nouveau display driver
ii  xserver-xorg-video-qxl                                      0.1.5-2build1                               amd64        X.Org X server -- QXL display driver
ii  xserver-xorg-video-radeon                                   1:18.0.1-1                                  amd64        X.Org X server -- AMD/ATI Radeon display driver
ii  xserver-xorg-video-vesa                                     1:2.3.4-1build3                             amd64        X.Org X server -- VESA display driver
ii  xserver-xorg-video-vmware                                   1:13.2.1-1build1                            amd64        X.Org X server -- VMware display driver
bahadir@bahadir ~ $ apt list --upgradable
Listeleme... Bitti
Sonuç aynı yine fallback kipinde açılıyor
« Son Düzenleme: 06 Temmuz 2018, 10:55:35 Gönderen: bahadir1903 »
Bu paketleri kaldırmıştık neden yeniden kurdunuz?
Bu paketleri kaldırınız ve aşağıdaki komutların çıktısını paylaşınız.
sudo apt install -f
inxi -r
Ayrıca kurulu olmayan xserver-xorg-legacy paketini de kurmayı deneyebilirsiniz.
sudo apt install xserver-xorg-legacy
« Son Düzenleme: 06 Temmuz 2018, 12:47:07 Gönderen: Butterfly »
  • İleti: 14
Ben sizin söylediğiniz komutlar dışında bir komut çalıştırmadım. Yüklediğimiz paketlerden biriyle yuklenmiş olabilir. Bu paketleri kaldırdım ekran yine siyah ekranda kalıyor. Login sayfası gelmiyor şuan.
« Son Düzenleme: 06 Temmuz 2018, 15:22:03 Gönderen: bahadir1903 »
sudo apt update
Bunu yeniden uygulayın, masaüstüne ulaştıktan sonra aşağıdaki komutun çıktısını paylaşın.
dpkg -l | egrep 'nvidia|bumblebee|primus|bbswitch'
  • İleti: 14
bahadir@bahadir ~ $ dpkg -l | egrep 'nvidia|bumblebee|primus|bbswitch'
yine yüklenmişler???
