Gönderen Konu: MSI GE60 20E Aşırı Isınma Sorunu  (Okunma sayısı 3945 defa)
Çevrimdışı mkaanyesillik
  • İleti: 11
    • Kaan Yeşillik Deneme
  • Dağıtım: Linux Mint 17.1
« : 29 Ağustos 2018, 15:03:38 »
 Boşta beklerken 70 derecelerde geziyor ubuntu da bunu yaşıyordum minte geçtim aynı windowsta sorun yok. istediğiniz çıktıları gönderebilirim. İyi günler şimdiden teşekkürler.
inxi -Fxxz Çıktısı
System:    Host: SyntaxBroker Kernel: 4.15.0-20-generic x86_64
           bits: 64 gcc: 7.3.0
           Desktop: Cinnamon 3.8.8 (Gtk 3.22.30-1ubuntu1) dm: lightdm
           Distro: Linux Mint 19 Tara
Machine:   Device: laptop System: Micro-Star product: GE60 2OC\2OD\2OE v: REV:1.0 serial: N/A
           Mobo: Micro-Star model: MS-16GC v: REV:0.B serial: N/A
           UEFI: American Megatrends v: E16GCIMS.517 date: 12/05/2013
           Chassis: type: 10 serial: N/A
Battery    BAT1: charge: 42.5 Wh 95.7% condition: 44.3/48.8 Wh (91%)
           volts: 12.3/11.1
           model: MSI PC-VP-BP77 serial: N/A status: N/A
CPU:       Quad core Intel Core i7-4700MQ (-MT-MCP-)
           arch: Haswell rev.3 cache: 6144 KB
           flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 19156
           clock speeds: min/max: 800/3400 MHz 1: 3080 MHz 2: 3077 MHz
           3: 3046 MHz 4: 3000 MHz 5: 2949 MHz 6: 2985 MHz 7: 2926 MHz
           8: 3049 MHz
           bus-ID: 00:02.0 chip-ID: 8086:0416
           Card-2: NVIDIA GK106M [GeForce GTX 765M]
           bus-ID: 01:00.0 chip-ID: 10de:11e2
           drivers: modesetting,nvidia (unloaded: fbdev,vesa,nouveau)
           Resolution: 1920x1080@60.00hz, 1920x1080@60.00hz
           OpenGL: renderer: GeForce GTX 765M/PCIe/SSE2
           version: 4.6.0 NVIDIA 390.48 Direct Render: Yes
Audio:     Card-1 Intel 8 Series/C220 Series High Def. Audio Controller
           driver: snd_hda_intel bus-ID: 00:1b.0 chip-ID: 8086:8c20
           driver: snd_hda_intel bus-ID: 00:03.0 chip-ID: 8086:0c0c
           Sound: Advanced Linux Sound Architecture v: k4.15.0-20-generic
Network:   Card-1: Qualcomm Atheros Killer E220x Gigabit Ethernet Controller
           driver: alx port: d000 bus-ID: 03:00.0 chip-ID: 1969:e091
           IF: enp3s0 state: down mac: <filter>
           Card-2: Realtek RTL8723AE PCIe Wireless Network Adapter
           driver: rtl8723ae port: c000 bus-ID: 05:00.0 chip-ID: 10ec:8723
           IF: wlp5s0 state: up mac: <filter>
Drives:    HDD Total Size: 1000.2GB (25.2% used)
           ID-1: /dev/sda model: HGST_HTS721010A9 size: 1000.2GB
           serial: <filter>
Partition: ID-1: / size: 181G used: 36G (21%) fs: ext4 dev: /dev/sda8
           ID-2: swap-1 size: 5.00GB used: 0.00GB (0%)
           fs: swap dev: /dev/sda7
           Unused Devices: none
Sensors:   System Temperatures: cpu: 62.0C mobo: 27.8C gpu: 0.0:56C
Info:      Processes: 291 Uptime: 2:00 Memory: 5259.0/15959.2MB
           Client: Shell (bash 4.4.191 running in gnome-terminal-) inxi: 2.3.56
« Son Düzenleme: 29 Ağustos 2018, 15:31:15 Gönderen: mkaanyesillik »
Ynt: MSI GE60 20E Aşırı Isınma Sorunu
« Yanıtla #1 : 29 Ağustos 2018, 15:08:35 »
  • İleti: 11
« Yanıtla #2 : 29 Ağustos 2018, 15:33:00 »
Kusura bakmayın Yeni kurduğum için Kurulum Öncesi ve Sonrası Bölümüne Açtım. inxi çıktısını paylaştım yardımcı olabilecek birisi varsa çok sevinirim.
« Yanıtla #3 : 29 Ağustos 2018, 15:45:16 »
Nvidia ayar yöneticisinin "Prime Profiles" kısmından güç tasarruf kipini seçiniz. Bu durumda da çok değişiklik olmazsa buradaki açıklamaları inceleyiniz.
