Gönderen Konu: [Çözüldü] Linux Mint 19 - Ralink MT7601U Kablosuz Ağ Aygıtı Tanıtma Sorunu  (Okunma sayısı 4903 defa)
Çevrimdışı adalifth
  • İleti: 7
Dün Linux mint 19 cinnamon yüklemesi yaptım. Fakat wifi bağlantısı yapamıyorum. Konuyla ilgili yardımcı olursanız sevinirim.
System:    Host: msa-G31T-M7 Kernel: 4.15.0-20-generic x86_64
           bits: 64 gcc: 7.3.0
           Desktop: Cinnamon 3.8.8 (Gtk 3.22.30-1ubuntu1) dm: lightdm
           Distro: Linux Mint 19 Tara
Machine:   Device: desktop Mobo: ECS model: G31T-M7 v: 1.0 serial: N/A
           BIOS: American Megatrends v: 080014 date: 07/31/2008
Network:   Card-1: Qualcomm Atheros Attansic L2 Fast Ethernet
           driver: atl2 v: 2.2.3 bus-ID: 01:00.0 chip-ID: 1969:2048
           IF: ens32 state: up speed: 100 Mbps duplex: full mac: <filter>
           Card-2: Ralink MT7601U Wireless Adapter
           usb-ID: 001-008 chip-ID: 148f:7601
           IF: null-if-id state: N/A mac: N/A
01:00.0 Ethernet controller [0200]: Qualcomm Atheros Attansic L2 Fast Ethernet [1969:2048] (rev a0)
Subsystem: Elitegroup Computer Systems Attansic L2 Fast Ethernet [1019:2048]
Kernel driver in use: atl2
Kernel modules: atl2
msa@msa-G31T-M7:~$ lsusb
Bus 001 Device 007: ID 058f:6362 Alcor Micro Corp. Flash Card Reader/Writer
Bus 001 Device 008: ID 148f:7601 Ralink Technology, Corp. MT7601U Wireless Adapter
Bus 003 Device 002: ID 046d:c52f Logitech, Inc. Unifying Receiver
  *-network
       açıklama: Eternet interface
       ürün: Attansic L2 Fast Ethernet
       üretici: Qualcomm Atheros
       physical id: 0
       bus info: pci@0000:01:00.0
       mantıksal ad: ens32
       sürüm: a0
       serial: 00:21:97:90:1b:73
       boyut: 100Mbit/s
       kapasite: 100Mbit/s
       genişlik: 64 bits
       saat: 33MHz
       kapasiteler: pm msi pciexpress vpd bus_master cap_list rom eternet physical tp 10bt 10bt-fd 100bt 100bt-fd autonegotiation
       yapılandırma: autonegotiation=on broadcast=yes driver=atl2 driverversion=2.2.3 duplex=full firmware=L2 ip=192.168.0.34 latency=0 link=yes multicast=yes port=twisted pair speed=100Mbit/s
       kaynaklar: irq:26 bellek:febc0000-febfffff bellek:feba0000-febbffff
ens32     no wireless extensions.
gpio_ich               16384  0
snd_hda_codec_via      24576  1
snd_hda_codec_generic    73728  1 snd_hda_codec_via
snd_hda_codec         126976  3 snd_hda_intel,snd_hda_codec_generic,snd_hda_codec_via
snd_hda_core           81920  4 snd_hda_intel,snd_hda_codec,snd_hda_codec_generic,snd_hda_codec_via
snd_pcm                98304  3 snd_hda_intel,snd_hda_codec,snd_hda_core
snd                    81920  16 snd_hda_intel,snd_hwdep,snd_seq,snd_hda_codec,snd_timer,snd_rawmidi,snd_hda_codec_generic,snd_seq_device,snd_pcm,snd_hda_codec_via
sch_fq_codel           20480  2
parport_pc             36864  1
ip_tables              28672  0
btrfs                1122304  0
usb_storage            69632  1 uas
hid                   118784  3 hid_generic,usbhid
i915                 1617920  3
atl2                   32768  0
video                  40960  1 i915
drm_kms_helper        167936  1 i915
floppy                 77824  0
drm                   401408  5 i915,drm_kms_helper
rfkill list yazdığımda herhangi bir çıktı alamıyorum.
Şimdiden teşekkür ederim.
Düzenleme: Konu başlığı
« Son Düzenleme: 22 Eylül 2018, 20:31:04 Gönderen: adalifth »
Lütfen açtığınız konularda, bir aygıt ile ilgili sorun yaşıyorsanız bunun adını konu başlığında belirtiniz. Bu aygıt ile ilgili forum içinde öneriler mevcut, lütfen konu açmadan önce forum içi arama yapmayı ihmal etmeyelim. Bu hususlarla ilgili aşağıdaki konumuzu inceleyebilirsiniz.
Buradaki öneriyi uygulamayı deneyiniz. Kurulum sırasında internet bağlantınızın olması gerekecek.
« Son Düzenleme: 21 Eylül 2018, 18:51:23 Gönderen: Butterfly »
Çevrimdışı adalifth
  • İleti: 7
Kusura bakmayın bütün konuları kontrol ettim fakat bir sonuca ulaşamadım o yüzden yazmak durumunda kaldım. Konu açarken daha dikkatli olurum.
Bağlantıyı düzelttim. Eğer internet bağlantınız yoksa, Linux Mint 19 için buradaki paketi indirip, Linux Mint 19 altında sağ tık Gdebi ile kurmayı deneyebilirsiniz. Sonrasında sistemi yeniden başlatınız ve secure boot özelliğinin BIOS'tan kapalı olduğundan emin olunuz.
Çevrimdışı adalifth
  • İleti: 7
Dediklerinizin hepsini uyguladım hala bir sonuç alamadım.
Çevrimdışı adalifth
  • İleti: 7
Kullandığım pc de secure boot özelliği yok. Daha önce ubuntu kullanıyordum böyle bir sıkıntı yaşamadım. Pardus ve mint'te bu sorunu yaşıyorum. Bu sorundan dolayı pardus'u silip mint'e döndüm ama aynı sıkıntı burda da var
Böyle bir şey olması zor bir durum, çünkü Linux Mint Ubuntu tabanını kullanır, yani donanımsal olarak Ubuntu'da yaşadığınız her olumlu ya da olumsuz durumu teknik olarak Linux Mint'te de görürsünüz.
Şimdi aşağıdaki komutların çıktılarına bakalım.
dkms status
dpkg -l | grep mt7601-sta-dkms
modinfo mt7601u
Not: mt7601u sürücü modülünü kendi sistemimde kontrol ettiğimde mevcut olduğunu gördüm. Şu an sizin sisteminiz güncel değil, belki güncellemeler ile sisteme eklenmiş olabilir. Bu durumda sisteminizi güncellemeyi deneyiniz.
Çevrimdışı adalifth
  • İleti: 7
mt7601, 3.0.0.4: added
ii  mt7601-sta-dkms                            3.0.0.4-0~201805101700~rev26~pkg4~ubuntu18.04.1 all          Ralink MT7601 driver in DKMS format.
filename:       /lib/modules/4.15.0-20-generic/kernel/drivers/net/wireless/mediatek/mt7601u/mt7601u.ko
license:        GPL
firmware:       mt7601u.bin
srcversion:     D06F3ABB275F34B500D150A
alias:          usb:v7392p7710d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2A5Fp1000d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2955p1001d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2955p0001d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2717p4106d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v2001p3D04d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v148Fp760Dd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v148Fp760Cd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v148Fp760Bd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v148Fp760Ad*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v148Fp7601d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v13D3p3434d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v13D3p3431d*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0E8Dp760Bd*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0E8Dp760Ad*dc*dsc*dp*ic*isc*ip*in*
alias:          usb:v0B05p17D3d*dc*dsc*dp*ic*isc*ip*in*
depends:        mac80211,cfg80211
retpoline:      Y
intree:         Y
vermagic:       4.15.0-20-generic SMP mod_unload
signat:         PKCS#7
signer:
sig_key:
sig_hashalgo:   md4
Aşağıdaki komutla sürücüyü etkinleştirmeyi dener misiniz?
sudo modprobe mt7601u
Çevrimdışı adalifth
  • İleti: 7
İlk başta bu komutu yazınca ağları gördü fakat bağlantı başarısız dedi. Bende pc yi yeniden başlattım bu sefer kablosuz bağlantı kayboldu. Aygıtı çıkarıp takınca normale döndü ve bağlantı kuruldu. Eğer kablosuz ağı görmezse aygıtı çıkarıp takarım. Çok teşekkür ederim yardımlarınız için.
Şu an çekirdekle gelen sürücü kullanıyor sanırım, bu sebeple aşağıdaki komutlarla eklediğiniz dkms sürücüsünü kaldırıp sistemi yeniden başlatmayı deneyiniz.
sudo apt purge mt7601-sta-dkms
Ayrıca sisteminizi güncelleyiniz, ilk başlatma sırasında aygıtın etkinleşmemesi bir çekirdek hatası olabilir ve güncellemelerle çözülmüş olabilir.
Çevrimdışı adalifth
  • İleti: 7
Sürücüyü kaldırdım ve normale döndü. Yardımlarınız için çok teşekkür ederim. Bu arada güncelleştirmeyide yaptım.
Rica ederiz.
