Gönderen Konu: [Çözüldü] Linux Mint ekran çözünürlüğü sorunsalı.  (Okunma sayısı 3854 defa)
Çevrimdışı Neptunmavisi
  • İleti: 41
  • Dağıtım: Linux Mint 19
  • Grafik Kartı: Nvidia onboard 7025
PC'yi yeniden başlattım, Ekran çözünürlüğü oldukça düştü. Normalde kullandığım çözünürlük, 1680X1XXX idi.
nivo@nivo-pc:~$ xrandr --output VGA-0 --set underscan off
warning: output VGA-0 not found; ignoring
X Error of failed request:  BadRROutput (invalid Output parameter)
  Major opcode of failed request:  140 (RANDR)
  Minor opcode of failed request:  15 (RRGetOutputProperty)
  Serial number of failed request:  24
  Current serial number in output stream:  24
Screen 0: minimum 320 x 200, current 1024 x 768, maximum 8192 x 8192
VGA-1 connected primary 1024x768+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
   1024x768      60.00*
   800x600       60.32    56.25
   848x480       60.00
   640x480       59.94
nivo@nivo-pc:~$ lspci -vnn | grep VGA -A 12
00:02.0 VGA compatible controller [0300]: Intel Corporation 4 Series Chipset Integrated Graphics Controller [8086:2e32] (rev 03) (prog-if 00 [VGA controller])
Subsystem: Gigabyte Technology Co., Ltd 4 Series Chipset Integrated Graphics Controller [1458:d000]
Flags: bus master, fast devsel, latency 0, IRQ 16
Memory at fd800000 (64-bit, non-prefetchable) [size=4M]
Memory at d0000000 (64-bit, prefetchable) [size=256M]
I/O ports at ff00 [size=8]
[virtual] Expansion ROM at 000c0000 [disabled] [size=128K]
Capabilities: <access denied>
Kernel driver in use: i915
Kernel modules: i915
00:1b.0 Audio device [0403]: Intel Corporation NM10/ICH7 Family High Definition Audio Controller [8086:27d8] (rev 01)
Subsystem: Gigabyte Technology Co., Ltd GA-D525TUD (Realtek ALC887) [1458:a002]
nivo@nivo-pc:~$ inxi -Fxxz
System:    Host: nivo-pc Kernel: 4.15.0-20-generic i686 bits: 32 gcc: 7.3.0
           Desktop: MATE 1.20.1 (Gtk 3.22.30-1ubuntu1) dm: lightdm
           Distro: Linux Mint 19 Tara
Machine:   Device: desktop Mobo: Gigabyte model: G41MT-S2PT serial: N/A
           BIOS: Award v: FA date: 08/03/2011
CPU:       Dual core Intel Pentium Dual E2180 (-MCP-)
           arch: Conroe rev.13 cache: 1024 KB
           flags: (lm nx pae sse sse2 sse3 ssse3) bmips: 8000
           clock speeds: min/max: 1200/2000 MHz 1: 1985 MHz 2: 1990 MHz
Graphics:  Card: Intel 4 Series Integrated Graphics Controller
           bus-ID: 00:02.0 chip-ID: 8086:2e32
           drivers: modesetting (unloaded: fbdev,vesa)
           Resolution: 1024x768@60.00hz
           OpenGL: renderer: Mesa DRI Intel G41 x86/MMX/SSE2
           version: 2.1 Mesa 18.0.5 Direct Render: Yes
Audio:     Card Intel NM10/ICH7 Family High Def. Audio Controller
           driver: snd_hda_intel bus-ID: 00:1b.0 chip-ID: 8086:27d8
           Sound: Advanced Linux Sound Architecture v: k4.15.0-20-generic
Network:   Card-1: Realtek RTL8111/8168/8411 PCIE Gigabit Ethernet Controller
           driver: r8169 v: 2.3LK-NAPI port: de00
           bus-ID: 02:00.0 chip-ID: 10ec:8168
           Card-2: Ralink RT5370 Wireless Adapter
           driver: rt2800usb v: 2.3.0 usb-ID: 001-003 chip-ID: 148f:5370
           IF: wlx6466b3186ce2 state: N/A mac: N/A
Drives:    HDD Total Size: 160.0GB (10.3% used)
           ID-1: /dev/sda model: WDC_WD1600AABS size: 160.0GB
           serial: <filter>
Partition: ID-1: / size: 146G used: 16G (12%) fs: ext4 dev: /dev/sda1
           Unused Devices: none
Sensors:   System Temperatures: cpu: 61.0C mobo: N/A
Info:      Processes: 143 Uptime: 7 min Memory: 546.2/1945.2MB
           Client: Shell (bash 4.4.191 running in mate-terminal) inxi: 2.3.56
nivo@nivo-pc:~$ dpkg -l | grep mesa
ii  libegl-mesa0:i386                          18.0.5-0ubuntu0~18.04.1             i386         free implementation of the EGL API -- Mesa vendor library
ii  libegl1-mesa:i386                          18.0.5-0ubuntu0~18.04.1             i386         transitional dummy package
ii  libgl1-mesa-dri:i386                       18.0.5-0ubuntu0~18.04.1             i386         free implementation of the OpenGL API -- DRI modules
ii  libgl1-mesa-glx:i386                       18.0.5-0ubuntu0~18.04.1             i386         transitional dummy package
ii  libglapi-mesa:i386                         18.0.5-0ubuntu0~18.04.1             i386         free implementation of the GL API -- shared library
ii  libgles2-mesa:i386                         18.0.5-0ubuntu0~18.04.1             i386         transitional dummy package
ii  libglu1-mesa:i386                          9.0.0-2.1build1                     i386         Mesa OpenGL utility library (GLU)
ii  libglx-mesa0:i386                          18.0.5-0ubuntu0~18.04.1             i386         free implementation of the OpenGL API -- GLX vendor library
ii  libwayland-egl1-mesa:i386                  18.0.5-0ubuntu0~18.04.1             i386         implementation of the Wayland EGL platform -- runtime
ii  mesa-utils                                 8.4.0-1                             i386         Miscellaneous Mesa GL utilities
nivo@nivo-pc:~$ inxi -r
Repos:     Active apt sources in file: /etc/apt/sources.list.d/official-package-repositories.list
           deb http://packages.linuxmint.com tara main upstream import backport #id:linuxmint_main
           deb http://archive.ubuntu.com/ubuntu bionic main restricted universe multiverse
           deb http://archive.ubuntu.com/ubuntu bionic-updates main restricted universe multiverse
           deb http://archive.ubuntu.com/ubuntu bionic-backports main restricted universe multiverse
           deb http://security.ubuntu.com/ubuntu/ bionic-security main restricted universe multiverse
           deb http://archive.canonical.com/ubuntu/ bionic partner
           Active apt sources in file: /etc/apt/sources.list.d/vivaldi.list
           deb http://repo.vivaldi.com/stable/deb/ stable main
nivo@nivo-pc:~$ ^C
nivo@nivo-pc:~$
« Son Düzenleme: 30 Aralık 2018, 03:00:45 Gönderen: Neptunmavisi »
Ynt: Linux Mint ekran çözünürlüğü sorunsalı.
« Yanıtla #1 : 29 Aralık 2018, 23:50:40 »
Çıkış aygıtının VGA-0 değil, VGA-1 olduğu xrandr çıktısında görünüyor. Bununla ilgili bir betik oluşturduysanız, buna göre düzeltmeyi deneyin.
  • İleti: 41
« Yanıtla #2 : 29 Aralık 2018, 23:55:43 »
Ben hiçbir şey oluşturmadım, Linux'ta betik oluşturacak kadar uzman olsaydım ne güzel olurdu tabikide.
Ne yapacağımı bilemiyorum. Nasıl yapmalıyım düzeltmeliyim?
Tekrar yeniden başlattım, fakat düzelmedi.
Monitorun arkasındaki VGA kablosu gevşemişti. Kabloyu iyice sıkıştırdım, sorun çözüldü.
Teşekkür ederim.
Başlık silinebilinir.
« Son Düzenleme: 30 Aralık 2018, 02:59:51 Gönderen: Neptunmavisi »
