Gönderen Konu: [Çözüldü] Linux Mint 19.1 Bumblebee Kurulmuyor  (Okunma sayısı 5183 defa)
Çevrimdışı nongliadin
  • İleti: 48
  • İşlemci: Intel(R) Core(TM) i5-2410M CPU @ 2.30GHz
"https://forum.linuxmint.net.tr/index.php?topic=9347.0" konudaki yönergeleri tek tek uyguladım fakat "optirun glxgears" kodunun çıktısını böyle alıyorum:
[  102.080505] [ERROR]Cannot access secondary GPU - error: [XORG] (EE) Failed to load module "mouse" (module does not exist, 0)
[  102.080538] [ERROR]Aborting because fallback start is disabled.
konuda belirtilen sorunlarla ilgili kodların çıktıları da bunlar:
buhari@Buhari:~$ optirun -vvv glxgears
[  304.595843] [DEBUG]Reading file: /etc/bumblebee/bumblebee.conf
[  304.596826] [DEBUG]optirun version 3.2.1 starting...
[  304.596865] [DEBUG]Active configuration:
[  304.596876] [DEBUG] bumblebeed config file: /etc/bumblebee/bumblebee.conf
[  304.596903] [DEBUG] X display: :8
[  304.596926] [DEBUG] LD_LIBRARY_PATH: /usr/lib/x86_64-linux-gnu:/usr/lib/i386-linux-gnu
[  304.596954] [DEBUG] Socket path: /var/run/bumblebee.socket
[  304.596981] [DEBUG] Accel/display bridge: auto
[  304.597002] [DEBUG] VGL Compression: proxy
[  304.597029] [DEBUG] VGLrun extra options:
[  304.597053] [DEBUG] Primus LD Path: /usr/lib/x86_64-linux-gnu/primus:/usr/lib/i386-linux-gnu/primus
[  304.597175] [DEBUG]Using auto-detected bridge primus
[  306.853525] [INFO]Response: No - error: [XORG] (EE) Failed to load module "mouse" (module does not exist, 0)
[  306.853576] [ERROR]Cannot access secondary GPU - error: [XORG] (EE) Failed to load module "mouse" (module does not exist, 0)
[  306.853595] [DEBUG]Socket closed.
[  306.853625] [ERROR]Aborting because fallback start is disabled.
[  306.853647] [DEBUG]Killing all remaining processes.
buhari@Buhari:~$ cat /etc/bumblebee/bumblebee.conf
# to take effect.
[bumblebeed]
VirtualDisplay=:8
KeepUnusedXServer=false
ServerGroup=bumblebee
# server exits.
TurnCardOffAtExit=false
# be ignored.
NoEcoModeOverride=false
Driver=
# Xorg binary to run
XorgBinary=/usr/lib/xorg/Xorg
[optirun]
# primus.
Bridge=auto
VGLTransport=proxy
# the primus bridge
# is not available?
AllowFallbackToIGC=false
[driver-nvidia]
KernelDriver=nvidia
PMMethod=auto
LibraryPath=/usr/lib/x86_64-linux-gnu:/usr/lib/i386-linux-gnu
# default Xorg modules path
XorgModulePath=/usr/lib/x86_64-linux-gnu/nvidia/xorg,/usr/lib/xorg/modules,/usr/lib/xorg/modules/input
[driver-nouveau]
KernelDriver=nouveau
PMMethod=auto
buhari@Buhari:~$ cat /etc/bumblebee/xorg.conf.nvidia
Section "ServerLayout"
    Identifier  "Layout0"
    Identifier  "DiscreteNvidia"
    Driver      "nvidia"
#   BusID "PCI:01:00:0"
    Option "ProbeAllGpus" "false"
    Option "NoLogo" "true"
    Option "UseEDID" "false"
buhari@Buhari:~$ cat /etc/modprobe.d/bumblebee.conf
# This file is installed by bumblebee, do NOT edit!
# to be used by kmod / module-init-tools, and installed in /etc/modprobe.d/
# or equivalent
# do not automatically load nouveau as it may prevent nvidia from loading
blacklist nouveau
# do not automatically load nvidia as it's unloaded anyway when bumblebeed
# starts and may fail bumblebeed to disable the card in a race condition.
# Debian
blacklist nvidia
blacklist nvidia-current
blacklist nvidia-legacy-304xx
blacklist nvidia-legacy-340xx
# Ubuntu
blacklist nvidia
blacklist nvidia-current-updates
# 304
blacklist nvidia-304
blacklist nvidia-304-updates
blacklist nvidia-experimental-304
# 310
blacklist nvidia-310
blacklist nvidia-310-updates
blacklist nvidia-experimental-310
# 313
blacklist nvidia-313
blacklist nvidia-313-updates
blacklist nvidia-experimental-313
# 319
blacklist nvidia-319
blacklist nvidia-319-updates
blacklist nvidia-experimental-319
# 325
blacklist nvidia-325
blacklist nvidia-325-updates
blacklist nvidia-experimental-325
# 331
blacklist nvidia-331
blacklist nvidia-331-updates
blacklist nvidia-experimental-331
# 334
blacklist nvidia-334
blacklist nvidia-334-updates
blacklist nvidia-experimental-334
# 337
blacklist nvidia-337
blacklist nvidia-337-updates
blacklist nvidia-experimental-337
# 340
blacklist nvidia-340
blacklist nvidia-340-updates
blacklist nvidia-experimental-340
# 343
blacklist nvidia-343
blacklist nvidia-343-updates
blacklist nvidia-experimental-343
# 346
blacklist nvidia-346
blacklist nvidia-346-updates
blacklist nvidia-experimental-346
# 349
blacklist nvidia-349
blacklist nvidia-349-updates
blacklist nvidia-experimental-349
# 352
blacklist nvidia-352
blacklist nvidia-352-updates
blacklist nvidia-experimental-352
# 355
blacklist nvidia-355
blacklist nvidia-355-updates
blacklist nvidia-experimental-355
# 358
blacklist nvidia-358
blacklist nvidia-358-updates
blacklist nvidia-experimental-358
# 361
blacklist nvidia-361
blacklist nvidia-361-updates
blacklist nvidia-experimental-361
# 364
blacklist nvidia-364
blacklist nvidia-364-updates
blacklist nvidia-experimental-364
# 367
blacklist nvidia-367
blacklist nvidia-367-updates
blacklist nvidia-experimental-367
# 375
blacklist nvidia-375
blacklist nvidia-375-updates
blacklist nvidia-experimental-375
# 378
blacklist nvidia-378
blacklist nvidia-378-updates
blacklist nvidia-experimental-378
# 381
blacklist nvidia-381
blacklist nvidia-381-updates
blacklist nvidia-experimental-381
# 384
blacklist nvidia-384
blacklist nvidia-384-updates
blacklist nvidia-experimental-384
buhari@Buhari:~$
buhari@Buhari:~$ cat /etc/X11/xorg.conf
buhari@Buhari:~$ dpkg -l | egrep 'nvidia|bumblebee|primus|prime|virtualgl'
ii  bumblebee                                  3.2.1-17                            amd64        NVIDIA Optimus support for Linux
ii  libnvidia-cfg1-390:amd64                   390.87-0ubuntu0~gpu18.04.1          amd64        NVIDIA binary OpenGL/GLX configuration library
ii  libnvidia-common-390                       390.87-0ubuntu0~gpu18.04.1          all          Shared files used by the NVIDIA libraries
ii  libnvidia-compute-390:amd64                390.87-0ubuntu0~gpu18.04.1          amd64        NVIDIA libcompute package
ii  libnvidia-decode-390:amd64                 390.87-0ubuntu0~gpu18.04.1          amd64        NVIDIA Video Decoding runtime libraries
ii  libnvidia-encode-390:amd64                 390.87-0ubuntu0~gpu18.04.1          amd64        NVENC Video Encoding runtime library
ii  libnvidia-fbc1-390:amd64                   390.87-0ubuntu0~gpu18.04.1          amd64        NVIDIA OpenGL-based Framebuffer Capture runtime library
ii  libnvidia-gl-390:amd64                     390.87-0ubuntu0~gpu18.04.1          amd64        NVIDIA OpenGL/GLX/EGL/GLES GLVND libraries and Vulkan ICD
ii  libnvidia-ifr1-390:amd64                   390.87-0ubuntu0~gpu18.04.1          amd64        NVIDIA OpenGL-based Inband Frame Readback runtime library
ii  nvidia-390                                 390.87-0ubuntu0~gpu18.04.1          amd64        Transitional package for nvidia-driver-390
ii  nvidia-compute-utils-390                   390.87-0ubuntu0~gpu18.04.1          amd64        NVIDIA compute utilities
ii  nvidia-dkms-390                            390.87-0ubuntu0~gpu18.04.1          amd64        NVIDIA DKMS package
ii  nvidia-driver-390                          390.87-0ubuntu0~gpu18.04.1          amd64        NVIDIA driver metapackage
ii  nvidia-kernel-common-390                   390.87-0ubuntu0~gpu18.04.1          amd64        Shared files used with the kernel module
ii  nvidia-kernel-source-390                   390.87-0ubuntu0~gpu18.04.1          amd64        NVIDIA kernel source package
ii  nvidia-utils-390                           390.87-0ubuntu0~gpu18.04.1          amd64        NVIDIA driver support binaries
ii  primus                                     0~20150328-6                        amd64        client-side GPU offloading for NVIDIA Optimus
ii  primus-libs:amd64                          0~20150328-6                        amd64        Shared libraries for primus
ii  primus-libs:i386                           0~20150328-6                        i386         Shared libraries for primus
ii  primus-libs-ia32:i386                      0~20150328-6                        i386         Shared libraries for primus (32-bit)
ii  xserver-xorg-video-nvidia-390              390.87-0ubuntu0~gpu18.04.1          amd64        NVIDIA binary Xorg driver
buhari@Buhari:~$ lspci | egrep 'VGA|3D|Display'
01:00.0 VGA compatible controller: NVIDIA Corporation GF119M [GeForce GT 520M] (rev a1)
buhari@Buhari:~$ cat /proc/cmdline
BOOT_IMAGE=/boot/vmlinuz-4.15.0-43-generic root=UUID=dd582962-9bb7-4b24-8d42-22f235baf53d ro nogpumanager quiet splash vt.handoff=1
buhari@Buhari:~$ cat /etc/environment
PATH="/usr/local/sbin:/usr/local/bin:/usr/sbin:/usr/bin:/sbin:/bin:/usr/games:/usr/local/games"
__GLVND_DISALLOW_PATCHING=1
buhari@Buhari:~$
Daha öncesinde ekran parlaklığını değiştiremediğim için şu yönergeleri takip etmiştim ve işe yaramıştı:https://forum.linuxmint.net.tr/index.php?topic=9513.15
https://forum.linuxmint.net.tr/index.php?topic=9456.msg57675#msg57675 burada yazdığınız gibi bumblebee yi tekrar yükledim. Artık böyle çıktı veriyor:
buhari@Buhari:~$ glxgears
Running synchronized to the vertical refresh.  The framerate should be
approximately the same as the monitor refresh rate.
buhari@Buhari:~$ optirun glxgears
[ 1265.275950] [ERROR]Cannot access secondary GPU - error: [XORG] (EE) Failed to load module "nvidia" (module does not exist, 0)
[ 1265.276052] [ERROR]Aborting because fallback start is disabled.
Sorunlar ile ilgili olan kodların çıktıları da belki değişmiştir diye tekrar atıyorum:
[ 1348.702311] [DEBUG]Reading file: /etc/bumblebee/bumblebee.conf
[ 1348.702815] [INFO]Configured driver: nvidia
[ 1348.703127] [DEBUG]optirun version 3.2.1 starting...
[ 1348.703157] [DEBUG]Active configuration:
[ 1348.703190] [DEBUG] bumblebeed config file: /etc/bumblebee/bumblebee.conf
[ 1348.703217] [DEBUG] X display: :8
[ 1348.703240] [DEBUG] LD_LIBRARY_PATH: /usr/lib/nvidia-340:/usr/lib32/nvidia-340
[ 1348.703262] [DEBUG] Socket path: /var/run/bumblebee.socket
[ 1348.703288] [DEBUG] Accel/display bridge: auto
[ 1348.703311] [DEBUG] VGL Compression: proxy
[ 1348.703334] [DEBUG] VGLrun extra options:
[ 1348.703360] [DEBUG] Primus LD Path: /usr/lib/x86_64-linux-gnu/primus:/usr/lib/i386-linux-gnu/primus
[ 1348.703503] [DEBUG]Using auto-detected bridge primus
[ 1348.723934] [INFO]Response: No - error: [XORG] (EE) Failed to load module "nvidia" (module does not exist, 0)
[ 1348.723957] [ERROR]Cannot access secondary GPU - error: [XORG] (EE) Failed to load module "nvidia" (module does not exist, 0)
[ 1348.723963] [DEBUG]Socket closed.
[ 1348.723976] [ERROR]Aborting because fallback start is disabled.
[ 1348.723982] [DEBUG]Killing all remaining processes.
# to take effect.
[bumblebeed]
VirtualDisplay=:8
# server exits.
# be ignored.
Driver=nvidia
[optirun]
# primus.
Bridge=auto
VGLTransport=proxy
# the primus bridge
# is not available?
[driver-nvidia]
Module=nvidia
[driver-nouveau]
PMMethod=auto
    Driver      "nvidia"
    BusID "PCI:01:00:0"
# or equivalent
blacklist nouveau
# Debian
blacklist nvidia
# Ubuntu
blacklist nvidia
# 304
# 310
# 313
# 319
# 325
# 331
# 334
# 337
# 340
# 343
# 346
# 349
# 352
# 355
# 358
# 361
# 364
# 367
# 375
# 378
# 381
# 384
# 340 karaliste
ii  libnvidia-compute-390:i386                 390.87-0ubuntu0~gpu18.04.1          i386         NVIDIA libcompute package
ii  libnvidia-decode-390:i386                  390.87-0ubuntu0~gpu18.04.1          i386         NVIDIA Video Decoding runtime libraries
ii  libnvidia-encode-390:i386                  390.87-0ubuntu0~gpu18.04.1          i386         NVENC Video Encoding runtime library
ii  libnvidia-fbc1-390:i386                    390.87-0ubuntu0~gpu18.04.1          i386         NVIDIA OpenGL-based Framebuffer Capture runtime library
iU  libnvidia-ifr1-390:amd64                   390.87-0ubuntu0~gpu18.04.1          amd64        NVIDIA OpenGL-based Inband Frame Readback runtime library
iU  libnvidia-ifr1-390:i386                    390.87-0ubuntu0~gpu18.04.1          i386         NVIDIA OpenGL-based Inband Frame Readback runtime library
iU  nvidia-driver-390                          390.87-0ubuntu0~gpu18.04.1          amd64        NVIDIA driver metapackage
ii  nvidia-prime                               0.8.8.2                             all          Tools to enable NVIDIA's Prime
ii  nvidia-settings                            415.25-0ubuntu0~gpu18.04.1          amd64        Tool for configuring the NVIDIA graphics driver
__GLVND_DISALLOW_PA
« Son Düzenleme: 07 Ocak 2019, 18:44:24 Gönderen: nongliadin »
Ynt: Linux Mint 19.1 Bumblebee Kurulmuyor
« Yanıtla #1 : 06 Ocak 2019, 22:03:42 »
Neden Nvidia-340 sürücüsünü kurdunuz, Bumblebee ile ilgili konudaki adımları uygulayıp sürücüleri kaldırınız. Ardından yeniden kurunuz.
Bu sorunla ilgili buradaki öneriyi uygulamayı deneyiniz. Linux Mint 19'da gedit yerine xed yazmalısınız.
  • İleti: 48
« Yanıtla #2 : 06 Ocak 2019, 22:52:09 »
Hocam 390 kurduğumda hep cinnamon masaüstü çöktü fallback kipinde açılıyor gibi bir uyarı alıyordum o yüzden 340 kurmuştum fakat şimdi tekrar yapınca oldu. Çarklar zaten dönüyordu. Öneriyi uyguladığımda çarklar yine dönüyor fakat optirun glxgears da şu çıktıyı alıyorum:
primus: fatal: failed to load any of the libraries: /usr/lib/nvidia-current/libGL.so.1:/usr/lib32/nvidia-current/libGL.so.1
/usr/lib/nvidia-current/libGL.so.1: cannot open shared object file: No such file or directory
/usr/lib32/nvidia-current/libGL.so.1: cannot open shared object file: No such file or directory
« Yanıtla #3 : 06 Ocak 2019, 23:04:12 »
Paketlerin kurulumundan sonraki adımları uygulamamışsınız sanırım.
Uyguladıysanız; Sorunlar Hakkında
  • İleti: 48
« Yanıtla #4 : 06 Ocak 2019, 23:12:57 »
[ 1414.216678] [DEBUG]Reading file: /etc/bumblebee/bumblebee.conf
[ 1414.217091] [INFO]Configured driver: nvidia
[ 1414.217389] [DEBUG]optirun version  starting...
[ 1414.217412] [DEBUG]Active configuration:
[ 1414.217421] [DEBUG] bumblebeed config file: /etc/bumblebee/bumblebee.conf
[ 1414.217430] [DEBUG] X display: :8
[ 1414.217438] [DEBUG] LD_LIBRARY_PATH: /usr/lib/nvidia-current:/usr/lib32/nvidia-current
[ 1414.217447] [DEBUG] Socket path: /var/run/bumblebee.socket
[ 1414.217456] [DEBUG] Accel/display bridge: auto
[ 1414.217479] [DEBUG] VGL Compression: proxy
[ 1414.217508] [DEBUG] VGLrun extra options:
[ 1414.217516] [DEBUG] Primus LD Path: /usr/lib/x86_64-linux-gnu/primus:/usr/lib/i386-linux-gnu/primus
[ 1414.217541] [DEBUG]Using auto-detected bridge primus
[ 1415.251365] [INFO]Response: Yes. X is active.
[ 1415.251387] [INFO]Running application using primus.
[ 1415.251524] [DEBUG]Process glxgears started, PID 24024.
[ 1415.255741] [DEBUG]SIGCHILD received, but wait failed with No child processes
[ 1415.255768] [DEBUG]Socket closed.
[ 1415.255786] [DEBUG]Killing all remaining processes.
# to take effect.
[bumblebeed]
VirtualDisplay=:8
# server exits.
# be ignored.
Driver=nvidia
[optirun]
# primus.
Bridge=auto
VGLTransport=proxy
# the primus bridge
# is not available?
[driver-nvidia]
Module=nvidia
LLibraryPath=/usr/lib/x86_64-linux-gnu:/usr/lib/i386-linux-gnu
[driver-nouveau]
PMMethod=auto
    Driver      "nvidia"
    BusID "PCI:01:00:0"
Section "Screen"
    Identifier "Default Screen"
    Device "DiscreteNvidia"
# or equivalent
blacklist nouveau
# Debian
blacklist nvidia
blacklist nvidia-legacy-390xx
# Ubuntu
blacklist nvidia
# 304
# 310
# 313
# 319
# 325
# 331
# 334
# 337
# 340
# 343
# 346
# 349
# 352
# 355
# 358
# 361
# 364
# 367
# 375
# 378
# 381
# 384
# 370
blacklist nvidia-370
blacklist nvidia-370-updates
blacklist nvidia-experimental-370
# 390
blacklist nvidia-390
blacklist nvidia-390-updates
blacklist nvidia-experimental-390
# 396
blacklist nvidia-396
blacklist nvidia-396-updates
blacklist nvidia-experimental-396
ii  bumblebee                                  3.2.1+git20181231-102~bionicppa1                   amd64        NVIDIA Optimus support for Linux
01:00.0 VGA compatible controller: NVIDIA Corporation GF119M [GeForce GT 520M] (rev ff)
BOOT_IMAGE=/boot/vmlinuz-4.15.0-43-generic root=UUID=dd582962-9bb7-4b24-8d42-22f235baf53d ro nogpumanager nogpumanager quiet splash vt.handoff=1
__GLVND_DISALLOW_PA
Hocam "cat /etc/X11/xorg.conf" bu komut sonrası böyle bir dosya yok diye uyarması normal mi?
« Yanıtla #5 : 06 Ocak 2019, 23:26:06 »
Linux Mint 19.x Bumblebee kurulumu ile ilgili konuda, Bumblebee PPA deposu eklenmesi ile ilgili bir adım mevcut değil. Bu depoyu yazılım kaynaklarından kaldırın, ardından aşağıdaki komutla paket bilgisi önbelleğini güncelleyin.
sudo apt update
Sonra tüm paketleri kaldırıp yeniden kurun ve yapılandırmayı deneyin.
Ayrıca nvidia-prime paketini de kaldırın, Bumblebee'de buna ihtyacınız yok.
  • İleti: 48
« Yanıtla #6 : 07 Ocak 2019, 17:57:44 »
sudo apt update
Sadece bu kısmı yaptım ve çalışmaya başladı hocam sağolasın. :D
