Gönderen Konu: [Çözüldü] AMD Trinity [Radeon HD 7560D] - Ekranda donma ve takılma  (Okunma sayısı 6828 defa)
Çevrimdışı harkail_rad
  • İleti: 115
  • Dağıtım: linux mint
Arkadaşlar merhaba,
Ekranımda donma ve takılma sorunu var. Geçikme yaşanıyor bir işlem yapıldığında.
Rica etsem yardımcı olabilir misiniz lütfen?
System:
  Host: WS-LIN-31 Kernel: 4.15.0-45-generic x86_64 bits: 64 compiler: gcc
  v: 7.3.0 Desktop: Cinnamon 4.0.9 Distro: Linux Mint 19.1 Tessa
  base: Ubuntu 18.04 bionic
Machine:
  Type: Desktop Mobo: ASUSTeK model: F2A55-M LE v: Rev X.0x serial: <filter>
  BIOS: American Megatrends v: 5105 date: 10/09/2012
CPU:
  Topology: Quad Core model: AMD A8-5600K APU with Radeon HD Graphics
  bits: 64 type: MCP arch: Piledriver rev: 1 L2 cache: 2048 KiB
  flags: lm nx pae sse sse2 sse3 sse4_1 sse4_2 sse4a ssse3 svm
  bogomips: 28943
  Speed: 1788 MHz min/max: 1400/3600 MHz Core speeds (MHz): 1: 1406 2: 1404
  3: 1768 4: 1858
Graphics:
  Device-1: AMD Trinity [Radeon HD 7560D] vendor: ASUSTeK driver: radeon
  v: kernel bus ID: 00:01.0
  Display: x11 server: X.Org 1.19.6 driver: ati,radeon
  unloaded: fbdev,modesetting,vesa resolution: 1366x768~60Hz
  OpenGL: renderer: AMD ARUBA (DRM 2.50.0 / 4.15.0-45-generic LLVM 7.0.0)
  v: 4.3 Mesa 18.2.2 direct render: Yes
Audio:
  Device-1: AMD Trinity HDMI Audio vendor: ASUSTeK driver: snd_hda_intel
  v: kernel bus ID: 00:01.1
  Device-2: AMD FCH Azalia vendor: ASUSTeK driver: snd_hda_intel v: kernel
  bus ID: 00:14.2
  Sound Server: ALSA v: k4.15.0-45-generic
Network:
  vendor: ASUSTeK P8 series driver: r8169 v: 2.3LK-NAPI port: e000
  bus ID: 03:00.0
  IF: enp3s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives:
  Local Storage: total: 577.55 GiB used: 80.08 GiB (13.9%)
  ID-1: /dev/sda model: ESA3SME2HTMTT120GB size: 111.79 GiB
  ID-2: /dev/sdb vendor: Western Digital model: WD5000AAKX-00ERMA0
Partition:
  ID-1: / size: 109.53 GiB used: 80.08 GiB (73.1%) fs: ext4 dev: /dev/sda1
Sensors:
  System Temperatures: cpu: 0.0 C mobo: N/A
  Fan Speeds (RPM): cpu: 0
Info:
  Processes: 211 Uptime: 6h 56m Memory: 3.32 GiB used: 1.43 GiB (43.1%)
  Init: systemd runlevel: 5 Compilers: gcc: 7.3.0 Shell: bash v: 4.4.19
  inxi: 3.0.27
« Son Düzenleme: 27 Şubat 2019, 11:22:48 Gönderen: harkail_rad »
Ynt: AMD Trinity [Radeon HD 7560D] - Ekranda donma ve takılma
« Yanıtla #1 : 25 Şubat 2019, 18:23:44 »
Graphics:
Radeon sürücüsü için şu mesajdaki öneriyi deneyebilirsiniz. https://forum.linuxmint.net.tr/index.php?topic=7873.msg48474#msg48474
  • İleti: 115
« Yanıtla #2 : 25 Şubat 2019, 20:43:51 »
Mesai başladığında deneyeceğim.
Şu soruyu yöneltmek istiyorum hocam.
Her radeon ekran kartında bunu mu uygulamalıyız.
« Son Düzenleme: 25 Şubat 2019, 20:45:15 Gönderen: harkail_rad »
« Yanıtla #3 : 25 Şubat 2019, 21:58:54 »
ATI/AMD HD 2000 serisi ve üstüne uygulayabilirsiniz. Bu yapılandırma genllikle tek GPU olan sistemlere uygun. Intel + AMD/ATI tarzı hibrit GPU sistemlere uygun olmayabilir.
  • İleti: 115
« Yanıtla #4 : 26 Şubat 2019, 08:11:23 »
Komutu çalıştırıken böyle bir hata aldım. Normal mi?
sudo xed /etc/X11/xorg.conf.d/20-radeon.conf
(xed:8472): Gdk-CRITICAL **: 08:08:52.713: gdk_window_get_window_type: assertion 'GDK_IS_WINDOW (window)' failed
(xed:8472): Gtk-CRITICAL **: 08:09:00.399: _gtk_widget_captured_event: assertion 'WIDGET_REALIZED_FOR_EVENT (widget, event)' failed
(xed:8472): Gtk-CRITICAL **: 08:09:00.400: _gtk_widget_captured_event: assertion 'WIDGET_REALIZED_FOR_EVENT (widget, event)' failed
(xed:8472): Gtk-CRITICAL **: 08:09:00.402: _gtk_widget_captured_event: assertion 'WIDGET_REALIZED_FOR_EVENT (widget, event)' failed
** (xed:8472): WARNING **: 08:09:06.925: Set document metadata failed: Öznitelik metadata::xed-spell-language ataması desteklenmiyor
** (xed:8472): WARNING **: 08:09:06.925: Set document metadata failed: Öznitelik metadata::xed-encoding ataması desteklenmiyor
** (xed:8472): WARNING **: 08:09:08.841: Set document metadata failed: Öznitelik metadata::xed-position ataması desteklenmiyor
Bu arada bilgisayarı yeniden başlattık. Hata vermedi hocam bilginiz olsun.
kullanıcı işlemlerinde bir sorun gözükmüyor.
Biraz test edip işin durumunu ona göre güncelleyeceğim inşaallah.
« Son Düzenleme: 26 Şubat 2019, 08:24:33 Gönderen: harkail_rad »
« Yanıtla #5 : 26 Şubat 2019, 14:15:51 »
Xed ile ilgili uyarılar önemli değil. Duruma göre geri dönüş yaparsınız.
  • İleti: 115
« Yanıtla #6 : 27 Şubat 2019, 11:22:30 »
Teşekkür ederim.
Gayet iyi görünüyor ekran.
