Gönderen Konu: Uzak masaüstü programda çalışırken donama ve takılma  (Okunma sayısı 3483 defa)
Çevrimdışı harkail_rad
  • İleti: 115
  • Dağıtım: linux mint
Aşağıdaki özelliklerde bir bilgisayara rdesktop uygulaması yükleyip windows suncuuya bağlantı kuruyoruz. Bu şekilde çalışan onlarca bilgisayar var bir kaç bilgisayarda uzak masaüstü bağlantı da çalışma sırasında donma ve kopma oluyor. Bunun sebebi ne olabilir acaba?
System:
  Host: WS-LIN-28 Kernel: 4.15.0-45-generic x86_64 bits: 64 compiler: gcc
  v: 7.3.0 Desktop: Cinnamon 4.0.9 Distro: Linux Mint 19.1 Tessa
  base: Ubuntu 18.04 bionic
Machine:
  Type: Desktop Mobo: Gigabyte model: A55M-DS2 v: x.x serial: <filter>
  UEFI: American Megatrends v: FB date: 03/19/2013
CPU:
  Topology: Triple Core model: AMD A6-3500 APU with Radeon HD Graphics
  bits: 64 type: MCP arch: Fusion L2 cache: 3072 KiB
  flags: lm nx pae sse sse2 sse3 sse4a svm bogomips: 12576
  Speed: 804 MHz min/max: 800/2100 MHz Core speeds (MHz): 1: 802 2: 812
  3: 818
Graphics:
  Device-1: AMD BeaverCreek [Radeon HD 6530D] vendor: Gigabyte
  driver: radeon v: kernel bus ID: 00:01.0
  Display: x11 server: X.Org 1.19.6 driver: ati,radeon
  unloaded: fbdev,modesetting,vesa resolution: 1280x1024~60Hz
  OpenGL: renderer: AMD SUMO (DRM 2.50.0 / 4.15.0-45-generic LLVM 7.0.0)
  v: 3.3 Mesa 18.2.2 direct render: Yes
Audio:
  Device-1: AMD BeaverCreek HDMI Audio [Radeon HD 6500D and 6400G-6600G
  series]
  vendor: Gigabyte driver: snd_hda_intel v: kernel bus ID: 00:01.1
  Device-2: AMD FCH Azalia vendor: Gigabyte driver: snd_hda_intel v: kernel
  bus ID: 00:14.2
  Sound Server: ALSA v: k4.15.0-45-generic
Network:
  vendor: Gigabyte driver: r8169 v: 2.3LK-NAPI port: e000 bus ID: 01:00.0
  IF: enp1s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
Drives:
  Local Storage: total: 689.33 GiB used: 33.37 GiB (4.8%)
  ID-1: /dev/sda model: ESA3ASA2PSTBT240GB size: 223.57 GiB
  ID-2: /dev/sdb vendor: Western Digital model: WD5000AAKX-00ERMA0
Partition:
  ID-1: / size: 218.57 GiB used: 33.36 GiB (15.3%) fs: ext4 dev: /dev/sda2
Sensors:
  System Temperatures: cpu: 37.1 C mobo: N/A gpu: radeon temp: 38 C
  Fan Speeds (RPM): N/A
Info:
  Processes: 181 Uptime: 3h 24m Memory: 7.28 GiB used: 1.45 GiB (19.8%)
  Init: systemd runlevel: 5 Compilers: gcc: 7.3.0 Shell: bash v: 4.4.19
  inxi: 3.0.27
Ynt: Uzak masaüstü programda çalışırken donama ve takılma
« Yanıtla #1 : 07 Mart 2019, 12:12:10 »
Buradaki Debian Buster deposundaki güncel sürümü, bir sisteme kurup test eder misiniz?
  • İleti: 115
« Yanıtla #2 : 07 Mart 2019, 13:00:57 »
Bu hatayı aldım
« Yanıtla #3 : 07 Mart 2019, 13:11:23 »
Aşağıdaki komutla Oepnssl ile ilgili PPA deposunu sisteme ekleyin.
sudo add-apt-repository ppa:mgrocock/openssl
Güncelleme yöneticisini yenileyip, Openssl ile ilgili güncellemeyi kurduktan sonra kurulumu yeniden deneyebilirsiniz.
  • İleti: 115
« Yanıtla #4 : 07 Mart 2019, 13:28:47 »
[sudo] password for user:
PPA eklenemiyor: '"Error reading https://launchpad.net/api/1.0/~mgrocock/+archive/opensll: (7, 'Failed to connect to launchpad.net port 443: Ba\\xc4\\x9flant\\xc4\\xb1da zaman a\\xc5\\x9f\\xc4\\xb1m\\xc4\\xb1')"'.
« Yanıtla #5 : 07 Mart 2019, 13:32:34 »
İnternet erişimi kısıtlıysa, erişimi kısıtlı olmayan bir makinede deneyebilirsiniz.
« Son Düzenleme: 07 Mart 2019, 13:33:59 Gönderen: Butterfly »
  • İleti: 115
« Yanıtla #6 : 07 Mart 2019, 13:45:06 »
$ sudo add-apt-repository ppa:mgrocock/openssl
sudo: unable to resolve host WS-LIN-01
"Bu PPA'nin xenial destegi yok"
PPA eklenemiyor: '"Bu PPA'nin xenial destegi yok"'.
user@WS-LIN-01 ~ $
« Yanıtla #7 : 07 Mart 2019, 13:49:12 »
Bu makina'da Linux Mint 18.x sürüm kurulduğu anlaşılıyor, Linux Mint 18.x serisi için aşağıdaki komutla eklenen PPA deposunu denemelisiniz.
sudo add-apt-repository ppa:carsten-uppenbrink-net/openssl
  • İleti: 115
« Yanıtla #8 : 07 Mart 2019, 14:08:28 »
Hocam oldu bu komut.
Paketi tekrar kurmaya çalıştım aşağıdaki hata ile karşılaştım.
« Son Düzenleme: 07 Mart 2019, 14:11:07 Gönderen: harkail_rad »
« Yanıtla #9 : 07 Mart 2019, 14:59:41 »
Aşağıdaki komutlarla openssl paketini güncellemeyi deneyiniz, sanırım paketi güncellemediniz.
sudo apt install openssl libssl1.1
« Son Düzenleme: 07 Mart 2019, 15:04:04 Gönderen: Butterfly »
