zahmet verdim kusura bakmayın başlığı yanlış açmışım bir daha dikkat ederim.
System: Host: fedora30 Kernel: 5.2.9-200.fc30.x86_64 x86_64 bits: 64 compiler: gcc v: 9.1.1 Desktop: Gnome 3.32.2
wm: gnome-shell dm: GDM Distro: Fedora release 30 (Thirty)
Machine: Type: Laptop System: ASUSTeK product: X556UQK v: 1.0 serial: <root required>
Mobo: ASUSTeK model: X556UQK v: 1.0 serial: <root required> UEFI: American Megatrends v: X556UQK.313
date: 03/13/2018
Graphics: Device-1: Intel HD Graphics 620 vendor: ASUSTeK driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:5916
Device-2: NVIDIA GM108M [GeForce 940MX] vendor: ASUSTeK driver: nvidia v: 430.40 bus ID: 01:00.0 chip ID: 10de:134d
Display: x11 server: Fedora Project X.org 1.20.5 driver: nvidia compositor: gnome-shell resolution: 1366x768~60Hz
OpenGL: renderer: GeForce 940MX/PCIe/SSE2 v: 4.6.0 NVIDIA 430.40 direct render: Yes
OpenGL renderer string: GeForce 940MX/PCIe/SSE2
GL_NV_compute_program5, GL_NV_conditional_render,
GL_EXT_multisampled_render_to_texture,
GL_EXT_multisampled_render_to_texture2, GL_EXT_occlusion_query_boolean,
GL_EXT_render_snorm, GL_EXT_robustness, GL_EXT_sRGB,
GL_NV_blend_minmax_factor, GL_NV_conditional_render, GL_NV_copy_buffer,
GL_NV_path_rendering, GL_NV_pixel_buffer_object, GL_NV_polygon_mode,
GL_OVR_multiview_multisampled_render_to_texture
00:02.0 VGA compatible controller: Intel Corporation HD Graphics 620 (rev 02)
01:00.0 3D controller: NVIDIA Corporation GM108M [GeForce 940MX] (rev a2)
xorg dosyası boş.
dediğim gibi çıktılarda bir sorun gözükmüyor. ama animasyonlar dalgalı çalışıyor. nvidia driver kuruldu ve sorunsuz çalışıyor.
