Gönderen Konu: Mint 19.2 Cinnamon lu sistemde harici ekran ile ekranın yarısında masaüstü büyüy  (Okunma sayısı 2194 defa)
Çevrimdışı nero
  • İleti: 1
  • Dağıtım: Lİnux Mint 19.2
  • Grafik Kartı: Nvidia 510 M
Mint 19.2 Cinnamon lu sistemde harici ekran ile ekranın yarısında masaüstü büyümüyor.Derdimi tam anlatamıyorum ama resim gerekeni anlatıyordur umarım.
inxi -SMGxx
System:
  Host: suat Kernel: 4.15.0-66-generic x86_64 bits: 64 compiler: gcc
  v: 7.4.0 Desktop: Cinnamon 4.2.4 wm: muffin dm: LightDM
Machine:
  Type: Portable System: Dell product: Dell System XPS L502X v: N/A
  serial: <root required> Chassis: type: 8 v: 0.1 serial: <root required>
  Mobo: Dell model: N/A serial: <root required> UEFI [Legacy]: Dell v: A12
  date: 09/07/2012
Graphics:
  Device-1: Intel 2nd Generation Core Processor Family Integrated Graphics
  vendor: Dell driver: i915 v: kernel bus ID: 00:02.0 chip ID: 8086:0116
  Device-2: NVIDIA GF108M [GeForce GT 540M] vendor: Dell driver: nouveau
  v: kernel bus ID: 01:00.0 chip ID: 10de:0df4
  Display: x11 server: X.Org 1.19.6 driver: modesetting,nouveau
  unloaded: fbdev,vesa resolution: 1024x768~60Hz, 1920x1080~60Hz
  OpenGL: renderer: Mesa DRI Intel Sandybridge Mobile v: 3.3 Mesa 19.0.8
01:00.0 VGA compatible controller: NVIDIA Corporation GF108M [GeForce GT 540M] (rev a1)
Screen 0: minimum 320 x 200, current 1920 x 1080, maximum 8192 x 8192
LVDS-1 connected (normal left inverted right x axis y axis)
   1920x1080     60.01 +  60.01    59.97    59.96    59.93
   1680x1050     59.95    59.88
   1600x1024     60.17
   1400x1050     59.98
   1280x1024     60.02
   1440x900      59.89
   1400x900      59.96    59.88
   1280x960      60.00
   1440x810      60.00    59.97
   1368x768      59.88    59.85
   1360x768      59.80    59.96
   1152x864      60.00
   1024x768      60.04    60.00
   960x720       60.00
   928x696       60.05
   896x672       60.01
   960x600       59.93    60.00
   840x525       60.01    59.88
   864x486       59.92    59.57
   800x512       60.17
   700x525       59.98
   800x450       59.95    59.82
   640x512       60.02
   720x450       59.89
   700x450       59.96    59.88
   640x480       60.00    59.94
   720x405       59.51    58.99
   684x384       59.88    59.85
   680x384       59.80    59.96
   640x400       59.88    59.98
   576x432       60.06
   512x384       60.00
   512x288       60.00    59.92
   480x270       59.63    59.82
   400x300       60.32    56.34
   432x243       59.92    59.57
   320x240       60.05
   360x202       59.51    59.13
   320x180       59.84    59.32
VGA-1-2 connected primary 1024x768+0+0 (normal left inverted right x axis y axis) 0mm x 0mm
   1024x768      60.00*
   800x600       60.32    56.25
   848x480       60.00
   640x480       59.94
HDMI-1-2 connected 1920x1080+0+0 (normal left inverted right x axis y axis) 509mm x 286mm
   1920x1080     60.00*+  60.00    50.00    50.00    59.94    30.00    24.00    29.97    23.98
   1920x1080i    60.00    50.00    59.94
   1680x1050     59.95
   1400x1050     59.95
   1600x900      60.00
   1280x1024     75.02    60.02
   1440x900      59.90
   1280x800      59.91
   1152x864      75.00
   1280x720      60.00    60.00    50.00    59.94
   832x624       74.55
   800x600       75.00    60.32
   720x576       50.00
   720x480       60.00    59.94
   640x480       75.00    60.00    59.94
   720x400       70.08
  1024x768 (0x44) 65.000MHz -HSync -VSync
        h: width  1024 start 1048 end 1184 total 1344 skew    0 clock  48.36KHz
        v: height  768 start  771 end  777 total  806           clock  60.00Hz
  800x600 (0x45) 40.000MHz +HSync +VSync
        h: width   800 start  840 end  968 total 1056 skew    0 clock  37.88KHz
        v: height  600 start  601 end  605 total  628           clock  60.32Hz
  800x600 (0x46) 36.000MHz +HSync +VSync
        h: width   800 start  824 end  896 total 1024 skew    0 clock  35.16KHz
        v: height  600 start  601 end  603 total  625           clock  56.25Hz
  640x480 (0x48) 25.175MHz -HSync -VSync
        h: width   640 start  656 end  752 total  800 skew    0 clock  31.47KHz
        v: height  480 start  490 end  492 total  525           clock  59.94Hz
  1680x1050 (0x55) 146.250MHz -HSync +VSync
        h: width  1680 start 1784 end 1960 total 2240 skew    0 clock  65.29KHz
        v: height 1050 start 1053 end 1059 total 1089           clock  59.95Hz
  1280x1024 (0x59) 108.000MHz +HSync +VSync
        h: width  1280 start 1328 end 1440 total 1688 skew    0 clock  63.98KHz
        v: height 1024 start 1025 end 1028 total 1066           clock  60.02Hz
  1280x800 (0x5b) 71.000MHz +HSync -VSync
        h: width  1280 start 1328 end 1360 total 1440 skew    0 clock  49.31KHz
        v: height  800 start  803 end  809 total  823           clock  59.91Hz
ii  libdrm-amdgpu1:amd64                       2.4.97-1ubuntu1~18.04.1               amd64        Userspace interface to amdgpu-specific kernel DRM services -- runtime
ii  libdrm-amdgpu1:i386                        2.4.97-1ubuntu1~18.04.1               i386         Userspace interface to amdgpu-specific kernel DRM services -- runtime
ii  nvidia-prime-applet                        1.0.7                                 all          An applet for NVIDIA Prime
ii  xserver-xorg-video-amdgpu                  18.0.1-1                              amd64        X.Org X server -- AMDGPU display driver
dkms status
virtualbox, 5.2.32, 4.15.0-66-generic, x86_64: installed
« Son Düzenleme: 07 Kasım 2019, 19:53:13 Gönderen: nero »
Harici ekran bağlı olduğu halde, aşağıdaki bağlantıdaki komutların çıktılarını kod etiketi içinde foruma aktarınız, resim olarak paylaşmayınız.
Sizden çıktı paylaşmanızı istedim ama çıktıları yeni bir mesaj yerine eski mesajınızı düzenleyerek paylaşmışsınız. Böyle yaparsanız gerekli çıktıları paylaştığınızı anlamamız mümkün olmaz ya da rastgele biçimde konuya bakarsak farkına varabiliriz. benzer durumlarda çıktıları yeni bir mesaj olarak paylaşırsanız, yaptığınız güncellemeyi farkedebiliriz.
Menüden aratarak "Ekran" aracını açınız. Bu araçta "Ekranları Yansıt" seçeneğinin etkin olmadığından emin olunuz.
   1024x768      60.00*
Çıktılara göre VGA çıkışından ve HDMI çıkışından farklı ekranların bağlı olduğu görünüyor. VGA çıkışındaki çözünürlük, HDMI çıkışındaki çözünürlüğü kısıtlıyor olabilir.
Masaüstü simgelerinin tüm ekranlarda gösterilmesi isterseniz, "Sistem Ayarları"ndaki "Masaüstü" aracını kullanabilirsiniz.
« Son Düzenleme: 08 Kasım 2019, 15:42:11 Gönderen: Butterfly »
