Gönderen Konu: [Çözüldü] Sistem Donma Sorunu  (Okunma sayısı 14926 defa)
Çevrimdışı Scipio
  • İleti: 353
« : 09 Mayıs 2015, 16:07:17 »
Firefox'ta video izlerken ya da Wireless açma-kapama butonuna basınca sistem donuyor. Sıklıkla ikincisinde oluyor bu. Güç düğmesinden sistemi kapatana kadar da düzelmiyor.
System:    Host: bunyo-X550JK Kernel: 3.19.2-031902-generic x86_64 (64 bit, gcc: 4.6.3)
Machine:   Mobo: ASUSTeK model: X550JK version: 1.0 Bios: American Megatrends version: X550JK.302 date: 07/09/2014
CPU:       Dual core Intel Core i5-4200H CPU (-HT-MCP-) cache: 3072 KB flags: (lm nx sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx) bmips: 11174.8
           Clock Speeds: 1: 2909.812 MHz 2: 3039.312 MHz 3: 1605.296 MHz 4: 1603.656 MHz
           X.Org: 1.15.1 drivers: (unloaded: fbdev,vesa) FAILED: nouveau,intel Resolution: 1366x768@60.0hz
           GLX Renderer: Mesa DRI Intel Haswell Mobile GLX Version: 3.0 Mesa 10.1.3 Direct Rendering: Yes
Audio:     Card-1: Intel Xeon E3-1200 v3/4th Gen Core Processor HD Audio Controller driver: snd_hda_intel bus-ID: 00:03.0
           Card-2: Intel 8 Series/C220 Series Chipset High Definition Audio Controller driver: snd_hda_intel bus-ID: 00:1b.0
           Sound: Advanced Linux Sound Architecture ver: k3.19.2-031902-generic
           driver: r8169 ver: 2.3LK-NAPI port: d000 bus-ID: 04:00.1
           IF: eth0 state: down mac: 54:a0:50:c7:93:4b
           Card-2: Broadcom BCM43142 802.11b/g/n driver: wl bus-ID: 03:00.0
           IF: eth1 state: up mac: 30:10:b3:1e:c8:38
Drives:    HDD Total Size: 500.1GB (28.8% used) 1: id: /dev/sda model: HGST_HTS545050A7 size: 500.1GB
Partition: ID: / size: 96G used: 11G (12%) fs: ext4 ID: swap-1 size: 2.10GB used: 0.00GB (0%) fs: swap
Sensors:   System Temperatures: cpu: 42.0C mobo: N/A
Info:      Processes: 187 Uptime: 9 min Memory: 803.4/7867.6MB Runlevel: 2 Gcc sys: 4.8.2 Client: Shell inxi: 1.8.4
Edit: Az önce video izlerken de aynı şeyi yaşadım.
« Son Düzenleme: 18 Haziran 2015, 11:57:11 Gönderen: Scipio »
Ynt: Sistem Donma Sorunu
« Yanıtla #1 : 09 Mayıs 2015, 19:05:30 »
Grafik sürücüsü ile ilgili bir sorun olabilir, masaüstü Cinnamon mu?
Çevrimdışı Scipio
  • İleti: 353
« Yanıtla #2 : 10 Mayıs 2015, 10:24:30 »
Evet masaüstü Cinnamon. Genellikle Wireless butonunda yaşıyorum amabu sorunu. Daha demin sistem yeni açılmış olduğu halde oldu mesela.
« Yanıtla #3 : 11 Mayıs 2015, 08:42:46 »
Burada anlatıldığı biçimde günlük PPA deposundan geliştirici sürümü (şu an itibariyle 2.5 sürüm) yüklemeyi deneyebilirsiniz. Sorun devam ederse konuda önceki sürüme nasıl dönüleceği ile ilgili açıklama da mevcut.
Çevrimdışı Scipio
  • İleti: 353
« Yanıtla #4 : 11 Mayıs 2015, 14:32:11 »
Malesef işe yaramadı. Az önce yine aynı şeyi yaşadım.
« Yanıtla #5 : 11 Mayıs 2015, 15:04:04 »
Yine kablosuz ağı kapatıp açarken mi oluştu sorun? Kablosuz ağ aygıtını sistem çekmecesindeki simgeden mi yoksa klavye kısayolu ile mi kapatıp açıyorsunuz?
Çevrimdışı Scipio
  • İleti: 353
« Yanıtla #6 : 12 Mayıs 2015, 13:58:04 »
Panel üzerindeki uygulama aracılığı ile kapatıyorum.
« Yanıtla #7 : 12 Mayıs 2015, 14:29:33 »
Kablosuz ağı aşağıdaki komut ile pasifleştirince bir sorun yaşanıyor mu?
sudo rfkill block wifi
Kablosuz ağı tekrar etkinleştirmek aşağıdaki komut kullanılabilir.
sudo rfkill unblock wifi
Çevrimdışı Scipio
  • İleti: 353
« Yanıtla #8 : 12 Mayıs 2015, 16:27:21 »
Her deneyişimde olmuyor. O yüzden komutları da 10-15 sefer denedim. Herhangi bir kilitlenme olmadı. Soruna panel uygulamacığı sebep oluyormuş gibi duruyor ama onunla hiç ilgilenmeden sadece film izlediğim vakitlerde de aynı şeyi yaşadığım oldu.
« Yanıtla #9 : 12 Mayıs 2015, 17:03:43 »
Peki bu kilitlenme sorunu sırasında Nvidia GPU etkin oluyor mu?
Çıktıları bir bakalım.
optirun -vvv glxgears
Çevrimdışı Scipio
  • İleti: 353
« Yanıtla #10 : 12 Mayıs 2015, 17:08:07 »
[ 3263.642139] [DEBUG]Reading file: /etc/bumblebee/bumblebee.conf
[ 3263.642440] [INFO]Configured driver: nvidia
[ 3263.642613] [DEBUG]optirun version 3.2.1 starting...
[ 3263.642623] [DEBUG]Active configuration:
[ 3263.642626] [DEBUG] bumblebeed config file: /etc/bumblebee/bumblebee.conf
[ 3263.642629] [DEBUG] X display: :8
[ 3263.642632] [DEBUG] LD_LIBRARY_PATH: /usr/lib/nvidia-346:/usr/lib32/nvidia-346
[ 3263.642635] [DEBUG] Socket path: /var/run/bumblebee.socket
[ 3263.642639] [DEBUG] Accel/display bridge: auto
[ 3263.642642] [DEBUG] VGL Compression: proxy
[ 3263.642645] [DEBUG] VGLrun extra options:
[ 3263.642648] [DEBUG] Primus LD Path: /usr/lib/x86_64-linux-gnu/primus:/usr/lib/i386-linux-gnu/primus
[ 3263.642714] [DEBUG]Using auto-detected bridge virtualgl
[ 3266.323155] [INFO]Response: Yes. X is active.
[ 3266.323166] [INFO]Running application using virtualgl.
[ 3266.323238] [DEBUG]Process vglrun started, PID 4801.
10287 frames in 5.0 seconds = 2057.397 FPS
10432 frames in 5.0 seconds = 2086.376 FPS
10383 frames in 5.0 seconds = 2076.568 FPS
10322 frames in 5.0 seconds = 2064.250 FPS
10190 frames in 5.0 seconds = 2037.894 FPS
[VGL] ERROR: in readback--
[VGL]    247: Window has been deleted by window manager
[ 3295.542850] [DEBUG]SIGCHILD received, but wait failed with No child processes
[ 3295.542892] [DEBUG]Socket closed.
[ 3295.542907] [DEBUG]Killing all remaining processes.
# to take effect.
[bumblebeed]
VirtualDisplay=:8
KeepUnusedXServer=false
ServerGroup=bumblebee
# server exits.
TurnCardOffAtExit=false
# be ignored.
NoEcoModeOverride=false
Driver=nvidia
[optirun]
# primus.
Bridge=auto
VGLTransport=proxy
# the primus bridge
# is not available?
AllowFallbackToIGC=false
#         bbswitch - new in BB 3, recommended if available
#       switcheroo - vga_switcheroo method, use at your own risk
#             none - disable PM completely
[driver-nvidia]
KernelDriver=nvidia-346
PMMethod=auto
LibraryPath=/usr/lib/nvidia-346:/usr/lib32/nvidia-346
# default Xorg modules path
XorgModulePath=/usr/lib/nvidia-346/xorg,/usr/lib/xorg/modules
[driver-nouveau]
KernelDriver=nouveau
PMMethod=auto
Section "ServerLayout"
    Identifier  "Layout0"
    Option      "AutoAddDevices" "false"
    Option      "AutoAddGPU" "false"
    Identifier  "DiscreteNvidia"
    Driver      "nvidia"
#   If the X server does not automatically detect your VGA device,
#   you can manually set it here.
#   To get the BusID prop, run `lspci | egrep 'VGA|3D'` and input the data
#   as you see in the commented example.
#   This Setting may be needed in some platforms with more than one
#   nvidia card, which may confuse the proprietary driver (e.g.,
#   trying to take ownership of the wrong device). Also needed on Ubuntu 13.04.
    BusID "PCI:01:00:0"
#   Setting ProbeAllGpus to false prevents the new proprietary driver
#   instance spawned to try to control the integrated graphics card,
#   which is already being managed outside bumblebee.
#   This option doesn't hurt and it is required on platforms running
#   more than one nvidia graphics card with the proprietary driver.
#   (E.g. Macbook Pro pre-2010 with nVidia 9400M + 9600M GT).
#   If this option is not set, the new Xorg may blacken the screen and
#   render it unusable (unless you have some way to run killall Xorg).
    Option "ProbeAllGpus" "false"
    Option "NoLogo" "true"
    Option "UseEDID" "false"
ii  bumblebee                                   3.2.1-90~trustyppa1                                 amd64        NVIDIA Optimus support
ii  bumblebee-nvidia                            3.2.1-90~trustyppa1                                 amd64        NVIDIA Optimus support using the proprietary NVIDIA driver
rc  nvidia-304                                  304.125-0ubuntu0.0.1                                amd64        NVIDIA legacy binary driver - version 304.125
ii  nvidia-346                                  346.59-0ubuntu0~xedgers14.04.1                      amd64        NVIDIA binary driver - version 346.59
ii  nvidia-settings                             346.47-0ubuntu1~xedgers14.04.1                      amd64        Tool for configuring the NVIDIA graphics driver
ii  primus                                      20131127-1~trustyppa1                               amd64        client-side GPU offloading for NVIDIA Optimus
ii  primus-libs:amd64                           20131127-1~trustyppa1                               amd64        Shared libraries for primus
ii  primus-libs:i386                            20131127-1~trustyppa1                               i386         Shared libraries for primus
ii  primus-libs-ia32                            20131127-1~trustyppa1                               i386         Shared libraries for primus (32-bit)
01:00.0 3D controller: NVIDIA Corporation GM107M [GeForce GTX 850M] (rev ff)
« Yanıtla #11 : 12 Mayıs 2015, 17:16:21 »
Aşağıdaki komut ile nvidia-304 paketinisistemden kaldırabilirsiniz.
sudo apt-get purge nvidia-304
Bumblebee ile ilgili sorun görünmüyor.
Kilitlenme sorunu Nvidia GPU'yu etkinleştirerek çalıştırdığınız bir uygulama açıkken mi oluyor.
Örneğin Firefox, VLC gibi bir uygulamayı Nvidia GPU ile mi başlatıyorsunuz?
Eğer öyle ise bu uygulamaları Intel GPU ile çalıştırdığınızda donma sorununun olup olmadığını kontrol eder misiniz?
Çevrimdışı Scipio
  • İleti: 353
« Yanıtla #12 : 12 Mayıs 2015, 17:26:41 »
Yok hayır zaten Nvidia'yı çok nadir kullanıyorum. Yine de Firefox ve VLC'yi kontrol ettim. Komut satırlarında falan Nvidia ile ilgili bir şey
gözükmüyor.
« Yanıtla #13 : 12 Mayıs 2015, 17:39:08 »
Çekirdek sürümünü güncellemeyi deneyelim.
mkdir linux-3.19.8 && cd linux-3.19.8
wget -c --no-check-certificate kernel.ubuntu.com/~kernel-ppa/mainline/v3.19.8-vivid/linux-headers-3.19.8-031908-generic_3.19.8-031908.201505110938_amd64.deb
wget -c --no-check-certificate kernel.ubuntu.com/~kernel-ppa/mainline/v3.19.8-vivid/linux-headers-3.19.8-031908_3.19.8-031908.201505110938_all.deb
wget -c --no-check-certificate kernel.ubuntu.com/~kernel-ppa/mainline/v3.19.8-vivid/linux-image-3.19.8-031908-generic_3.19.8-031908.201505110938_amd64.deb
sudo dpkg -i  *.deb
Firefox'da video hızlandırma ayarları pasif mi?
http://forum.linuxmint.net.tr/index.php?topic=1156.msg6860#msg6860
http://forum.linuxmint.net.tr/index.php?topic=2776.msg17766#msg17766
Video seyretmek için VLC'yi mi kullanıyorsunuz?
« Yanıtla #14 : 12 Mayıs 2015, 18:21:06 »
Bir de paneldeki kablosuz ağ uygulamacığının bir özelliği geldi aklıma, Cinnamon'da istenirse klasik kipdeki ağ uygulmacığı kullanılabiliyor. Bunun için ağ uygulamacığına sağ tıklayıp "Bu uygulamacığı sil" seçeneği ile mevcut ağ uygulamacığını kaldırınız. Böyle yapınca sistem çekmesine otomatik olarak Gnome 2'den (ya da Mate) alışık olduğumuz uygulamacık geliyor. Bakalım bununla sorun olacak mı?
