Gönderen Konu: [Nasıl] Linux Mint 18 - Intel + Nvidia Hibrit GPU İçin Bumblebee Kurulumu  (Okunma sayısı 85822 defa)
Çevrimdışı BayramGrbz
  • İleti: 15
    • Bayram_grbz
  • Grafik Kartı: Nvdıa gtx 920m
  • İşlemci: Intel(R) Core(TM) i5-5200UCPU @2.20GHz 2.20GHz
optirun glxgears
kullandıgımda.
[  477.076517] [ERROR]Cannot access secondary GPU - error: [XORG] (EE) Failed to load module "nvidia" (module does not exist, 0)
[  477.076556] [ERROR]Aborting because fallback start is disabled.
cıktısını alıyorum
BayramGrbz
[warning]Sorunlar Hakkında[/warning]
  • İleti: 15
    • Bayram_grbz
optirun -vvv glxgears cıktısı
[ 5566.422168] [DEBUG]Reading file: /etc/bumblebee/bumblebee.conf
[ 5566.422376] [INFO]Configured driver: nvidia
[ 5566.422469] [DEBUG]optirun version 3.2.1 starting...
[ 5566.422478] [DEBUG]Active configuration:
[ 5566.422484] [DEBUG] bumblebeed config file: /etc/bumblebee/bumblebee.conf
[ 5566.422489] [DEBUG] X display: :8
[ 5566.422494] [DEBUG] LD_LIBRARY_PATH: /usr/lib/nvidia-381:/usr/lib32/nvidia-375
[ 5566.422498] [DEBUG] Socket path: /var/run/bumblebee.socket
[ 5566.422501] [DEBUG] Accel/display bridge: auto
[ 5566.422506] [DEBUG] VGL Compression: proxy
[ 5566.422512] [DEBUG] VGLrun extra options:
[ 5566.422518] [DEBUG] Primus LD Path: /usr/lib/x86_64-linux-gnu/primus:/usr/lib/i386-linux-gnu/primus
[ 5566.422551] [DEBUG]Using auto-detected bridge virtualgl
[ 5566.558445] [INFO]Response: No - error: [XORG] (EE) Failed to load module "nvidia" (module does not exist, 0)
[ 5566.558463] [ERROR]Cannot access secondary GPU - error: [XORG] (EE) Failed to load module "nvidia" (module does not exist, 0)
[ 5566.558471] [DEBUG]Socket closed.
[ 5566.558486] [ERROR]Aborting because fallback start is disabled.
[ 5566.558490] [DEBUG]Killing all remaining processes.
cat /etc/bumblebee/bumblebee.conf cıktısı
  Configuration file for Bumblebee. Values should **not** be put between quotes
# to take effect.
[bumblebeed]
VirtualDisplay=:8
KeepUnusedXServer=false
ServerGroup=bumblebee
# server exits.
TurnCardOffAtExit=false
# be ignored.
NoEcoModeOverride=false
Driver=nvidia
# Xorg binary to run
XorgBinary=/usr/lib/xorg/Xorg
[optirun]
# primus.
Bridge=auto
VGLTransport=proxy
# the primus bridge
# is not available?
AllowFallbackToIGC=false
[driver-nvidia]
KernelDriver=nvidia-375
PMMethod=auto
LibraryPath=/usr/lib/nvidia-381:/usr/lib32/nvidia-375
# default Xorg modules path
XorgModulePath=/usr/lib/nvidia-381/xorg,/usr/lib/xorg/modules
[driver-nouveau]
KernelDriver=nouveau
PMMethod=auto
cat /etc/bumblebee/xorg.conf.nvidia cıktısı
Section "ServerLayout"
    Identifier  "Layout0"
    Identifier  "DiscreteNvidia"
    Driver      "nvidia"
    BusID "PCI:04:00:0"
    Option "ProbeAllGpus" "false"
    Option "NoLogo" "true"
    Option "UseEDID" "false"
cat /etc/X11/xorg.conf cıktısı
dpkg -l | egrep 'nvidia|bumblebee|primus|prime|virtualgl' cıktısı
ii  bumblebee                                   3.2.1-98~xenialppa1                          amd64        NVIDIA Optimus support for Linux
ii  bumblebee-nvidia                            3.2.1-98~xenialppa1                          amd64        NVIDIA Optimus support using the proprietary NVIDIA driver
ii  nvidia-375                                  375.66-0ubuntu0.16.04.1                      amd64        NVIDIA binary driver - version 375.66
ii  nvidia-settings                             381.22-0ubuntu0~gpu16.04.1                   amd64        Tool for configuring the NVIDIA graphics driver
ii  primus                                      20150328-3~xenialppa2                        amd64        client-side GPU offloading for NVIDIA Optimus
ii  primus-libs:amd64                           20150328-3~xenialppa2                        amd64        Shared libraries for primus
ii  primus-libs:i386                            20150328-3~xenialppa2                        i386         Shared libraries for primus
ii  primus-libs-ia32:i386                       20150328-3~xenialppa2                        i386         Shared libraries for primus (32-bit)
ii  virtualgl                                   2.4.1-1~xenialppa1                           amd64        Toolkit for displaying OpenGL applications to thin clients
ii  virtualgl-libs:amd64                        2.4.1-1~xenialppa1                           amd64        Library files for virtualgl
lspci | egrep 'VGA|3D|Display' cıktısı
00:02.0 VGA compatible controller: Intel Corporation Broadwell-U Integrated Graphics (rev 09)
04:00.0 3D controller: NVIDIA Corporation GK208M [GeForce 920M] (rev a1)
cat /proc/cmdline cıktısı
BOOT_IMAGE=/boot/vmlinuz-4.4.0-79-generic root=UUID=5d5769c5-fb69-413b-8ced-19c12c30bc76 ro nogpumanager quiet splash vt.handoff=7
BayramGrbz
Öncelikle forumda anlatıldığı biçimde kurulum deneyiniz, forumdaki konuda Nvidia-381 sürücüsüne göre anlatım bulunmakta ama siz Nvidia-375 sürücüsünü kurmuşsunuz. Eğer Nvidia-375 sürücüsü ile devam etmek istiyorsanız  /etc/bumblebee/bumblebee.conf dosyasında nvidia-381 yazan yerleri nvidia-375 olarak değiştirin ve aşağıdaki komutla Bumblebee servisini yeniden başlatın.
Çevrimdışı ysfbkrcn
  • İleti: 26
  • Dağıtım: Linux Mint 18
  • Grafik Kartı: Nvidia 940mx
  • İşlemci: intel i5 7200u
aşağıdaki komutu çalıştırdığımda hata mesajı alıyorum:
optirun glxgears
Error: couldn't get an RGB, Double-buffered visual
yusuf@y560 ~ $ optirun -vvv glxgears
[  397.422812] [DEBUG]Reading file: /etc/bumblebee/bumblebee.conf
[  397.423383] [INFO]Configured driver: nvidia
[  397.423660] [DEBUG]optirun version 3.2.1 starting...
[  397.423681] [DEBUG]Active configuration:
[  397.423712] [DEBUG] bumblebeed config file: /etc/bumblebee/bumblebee.conf
[  397.423726] [DEBUG] X display: :8
[  397.423784] [DEBUG] LD_LIBRARY_PATH: /usr/lib/nvidia-current:/usr/lib32/nvidia-current
[  397.423789] [DEBUG] Socket path: /var/run/bumblebee.socket
[  397.423793] [DEBUG] Accel/display bridge: auto
[  397.423799] [DEBUG] VGL Compression: proxy
[  397.423802] [DEBUG] VGLrun extra options:
[  397.423805] [DEBUG] Primus LD Path: /usr/lib/nvidia-381:/usr/lib32/nvidia-381
[  397.423835] [DEBUG]Using auto-detected bridge virtualgl
[  397.776109] [INFO]Response: Yes. X is active.
[  397.776126] [INFO]Running application using virtualgl.
[  397.776241] [DEBUG]Process vglrun started, PID 5523.
[  397.782819] [DEBUG]SIGCHILD received, but wait failed with No child processes
[  397.782839] [DEBUG]Socket closed.
[  397.782855] [DEBUG]Killing all remaining processes.
yusuf@y560 ~ $ cat /etc/bumblebee/bumblebee.conf
# to take effect.
[bumblebeed]
VirtualDisplay=:8
# server exits.
# be ignored.
Driver=nvidia
[optirun]
# primus.
Bridge=auto
VGLTransport=proxy
# the primus bridge
PrimusLibraryPath=/usr/lib/nvidia-381:/usr/lib32/nvidia-381
# is not available?
[driver-nvidia]
KernelDriver=nvidia-381
PMMethod=auto
[driver-nouveau]
PMMethod=auto
yusuf@y560 ~ $ cat /etc/bumblebee/xorg.conf.nvidia
    Driver      "nvidia"
    BusID "PCI:01:00:0"
yusuf@y560 ~ $ cat /etc/X11/xorg.conf
yusuf@y560 ~ $ dpkg -l | egrep 'nvidia|bumblebee|primus|prime|virtualgl'
ii  bumblebee                                    3.2.1-100~xenialppa1                        amd64        NVIDIA Optimus support for Linux
ii  bumblebee-nvidia                             3.2.1-100~xenialppa1                        amd64        NVIDIA Optimus support using the proprietary NVIDIA driver
ii  nvidia-381                                   381.22-0ubuntu0~gpu16.04.2                  amd64        NVIDIA binary driver - version 381.22
yusuf@y560 ~ $ lspci | egrep 'VGA|3D|Display'
00:02.0 VGA compatible controller: Intel Corporation Device 5916 (rev 02)
01:00.0 3D controller: NVIDIA Corporation Device 179c (rev ff)
yusuf@y560 ~ $ cat /proc/cmdline
BOOT_IMAGE=/boot/vmlinuz-4.10.0-22-generic root=UUID=cecd7140-0be0-436b-8233-c472934df026 ro nogpumanager quiet splash vt.handoff=7
bumblebee.conf dosyasındaki aşağıdaki satırı,
konuda anlatıldığı biçimde düzenlemeyi deneyebilirsiniz.
Ayrıca aşağıdaki satırı,
aşağıdki şekilde değiştirip kaydedin, yani düzenlemeyi yanlış satırda yapmışsınız.
Sonrasında aşağıdaki şekilde Bumblebee servisini yeniden başlatınız.
Çevrimdışı ysfbkrcn
  • İleti: 26
sorun giderildi. teşekkürler.
Çevrimdışı eufratboss
  • İleti: 1
  • Grafik Kartı: Gtx 820m
  • İşlemci: i3-4030u
Uygulamayı yükledim gayet düzgün şekilde çalışıyor ama bumblebee'nin arayüzünden seçtiğim programlar ekran kartı ile çalıştırılmıyor. Aynı programları uçbirim ile denediğimde sıkıntısız çalışıyor.
Çevrimdışı Starseemer
  • İleti: 4
  • Dağıtım: Linux Mint 18.2 kde
Bumblebee kurulumunu yaptıktan sonra sistem çekmecemde active grapich card : unknown diye bir simge çıktı bende herşeyin doğru çalışıp çalışmadığına bakmak için sizin paylaşmış olduğunuz kodları çalıştırdım ve
böyle bir şeyle karşılaştım sanırım bunnun alakalı problemim yardımcı olabilir misiniz
Aşağıdaki komutla nvidia-prime ve nvidia-prime-applet paketlerini kaldırmayı deneyiniz.
sudo apt-get purge nvidia-prime nvidia-prime-applet
Cinnamon masaüstünü kullanıyorsanız Bumblebee-ui uygulamacığına ihtiyacınız yok, menüden istediğiniz uygulamaya sağ tıklayıp Nvidia GPU ile açabilirsiniz.
https://forum.linuxmint.net.tr/index.php?topic=6649.0
Sorun yaşanırsa aşağıdaki konuyu inceleyiniz.
https://forum.linuxmint.net.tr/index.php?topic=8243.0
Çevrimdışı jaws61
  • İleti: 29
  • Dağıtım: Manjaro-Deepin-Mint
  • Masaüstü Ortamı: Cinnamon-Deepin
  • Grafik Kartı: Nvidia optimus Gt 540 M
  • İşlemci: İntel
İnşa bölümüne gelen tüm komutları uyguladım ve değişiklikleri yaptım. Fakat cihazı yeniden başlattığımda ekran gelmiyor. Uzun süre bekledim ama yine de siyah ekrandan öteye geçemedim.
Tavsiyeleriniz nedir ?
Aşağıdaki şekilde masaüstüne ulaşmayı deneyiniz.
Grub önyükleyici menüsü => Gelişmiş seçenekler  altındaki kurtarma kipi (recovery mode) seçeneği ile sistemi başlatın. Bir süre sonra bir menü daha gelecek, burada "resume" seçeneğini seçerek devam edin.
Grub menüsü başlangıçta görünmüyorsa, açılış sırasında üst karakter (shift) tuşuna basmayı deneyin.
Masaüstüne ulaştığınızda konuda anlatıldığı biçimde kurulumu kaldırıp, yeniden kurulum yapmayı deneyebilirsiniz.
Çevrimdışı jaws61
  • İleti: 29
  • İşlemci: İntel
Linux mint i tekrar kurdum ve aynı komutları tekrar uyguladım. Sonrasında yine linux mint açılmadı. Recovery moda girmeyi denediğimde ise mavi bir ekran geliyor ve ekran donuyor. Anlamadığım bu iş kolaylaşacağına niye zorlaşmış acaba :))
Paketlerin tamamını kaldırıp, Bumblebee yerine Nvidia Prime kurmak denenebilir. İlla Bumblebee seçeneği isteniyorsa, Ekran kartı ile ilgili çıktılarla birlikte, kurulum sırasındaki çıktıları da foruma aktarırsanız incelme yapabiliriz.
