Gönderen Konu: [Nasıl] Linux Mint 17.x - Intel + Nvidia Hibrit GPU İçin Bumblebee Kurulumu  (Okunma sayısı 193580 defa)
Çevrimdışı chaosx
  • İleti: 10
minti silip yeniden yükledim ve baştan anlatılanlar gibi kurdum optirun glxgears komutuna şu hatayı alıyorum:
[  705.030619] [ERROR]Cannot access secondary GPU - error: [XORG] (EE) NVIDIA(0): Failed to initialize the NVIDIA GPU at PCI:1:0:0.  Please
[  705.030662] [ERROR]Aborting because fallback start is disabled.
optirun -vvv glxgears
[ 1063.794013] [DEBUG]Reading file: /etc/bumblebee/bumblebee.conf
[ 1063.794381] [DEBUG]optirun version 3.2.1 starting...
[ 1063.794390] [DEBUG]Active configuration:
[ 1063.794394] [DEBUG] bumblebeed config file: /etc/bumblebee/bumblebee.conf
[ 1063.794397] [DEBUG] X display: :8
[ 1063.794401] [DEBUG] LD_LIBRARY_PATH: /usr/lib/nvidia-304:/usr/lib32/nvidia-304
[ 1063.794404] [DEBUG] Socket path: /var/run/bumblebee.socket
[ 1063.794407] [DEBUG] Accel/display bridge: auto
[ 1063.794410] [DEBUG] VGL Compression: proxy
[ 1063.794413] [DEBUG] VGLrun extra options:
[ 1063.794417] [DEBUG] Primus LD Path: /usr/lib/x86_64-linux-gnu/primus:/usr/lib/i386-linux-gnu/primus
[ 1063.794455] [DEBUG]Using auto-detected bridge primus
[ 1063.830964] [INFO]Response: No - error: [XORG] (EE) NVIDIA(0): Failed to initialize the NVIDIA GPU at PCI:1:0:0.  Please
[ 1063.830984] [ERROR]Cannot access secondary GPU - error: [XORG] (EE) NVIDIA(0): Failed to initialize the NVIDIA GPU at PCI:1:0:0.  Please
[ 1063.830991] [DEBUG]Socket closed.
[ 1063.831012] [ERROR]Aborting because fallback start is disabled.
[ 1063.831018] [DEBUG]Killing all remaining processes.
# to take effect.
[bumblebeed]
VirtualDisplay=:8
KeepUnusedXServer=false
ServerGroup=bumblebee
# server exits.
TurnCardOffAtExit=false
# be ignored.
NoEcoModeOverride=false
Driver=
[optirun]
# primus.
Bridge=auto
VGLTransport=proxy
# the primus bridge
# is not available?
AllowFallbackToIGC=false
[driver-nvidia]
KernelDriver=nvidia-current
PMMethod=auto
# default Xorg modules path
[driver-nouveau]
KernelDriver=nouveau
PMMethod=auto
Section "ServerLayout"
    Identifier  "Layout0"
    Identifier  "DiscreteNvidia"
    Driver      "nvidia"
    BusID "PCI:01:00:0"
    Option "ProbeAllGpus" "false"
    Option "NoLogo" "true"
    Option "UseEDID" "false"
dpkg -l | egrep 'nvidia|bumblebee'
ii  bumblebee                                   3.2.1-90~trustyppa1                                 amd64        NVIDIA Optimus support
ii  bumblebee-nvidia                            3.2.1-90~trustyppa1                                 amd64        NVIDIA Optimus support using the proprietary NVIDIA driver
ii  nvidia-304                                  304.117-0ubuntu1                                    amd64        NVIDIA legacy binary driver - version 304.117
ii  nvidia-current                              304.117-0ubuntu1                                    amd64        Transitional package for nvidia-current
sorun çözüldü
sudo apt-get install nvidia-331-updates
sudo gedit /etc/bumblebee/bumblebee.conf
ile dosyayı açıp ,aşağıda ile değiştirdiğinizde problem önleniyor
# to take effect.
[bumblebeed]
VirtualDisplay=:8
# server exits.
# be ignored.
Driver=nvidia
[optirun]
# primus.
Bridge=auto
VGLTransport=proxy
# the primus bridge
# is not available?
[driver-nvidia]
KernelDriver=nvidia-331-updates
PMMethod=auto
LibraryPath=/usr/lib/nvidia-331-updates:/usr/lib32/nvidia-331-updates
XorgModulePath=/usr/lib/nvidia-331-updates/xorg,/usr/lib/xorg/modules
[driver-nouveau]
PMMethod=auto
« Son Düzenleme: 12 Temmuz 2014, 12:03:02 Gönderen: chaosx »
Konu için bu sorunun çözümü mevcut, burada anlatıldığı biçimde nvidia-304 sürücüsünü silip nvidia-331 sürücüsünü kurun ve bumblebee.conf dosyasında istenilen değişiklikleri yapın.
« Son Düzenleme: 12 Temmuz 2014, 21:51:45 Gönderen: Butterfly »
Çevrimdışı damocles
  • İleti: 14
  • Dağıtım: mint 17 cinnamon
optirun glxgears
X Error of failed request:  BadMatch (invalid parameter attributes)
  Major opcode of failed request:  72 (X_PutImage)
  Serial number of failed request:  39
  Current serial number in output stream:  42
Kurmaya çalıştım,kontrol ettiğim zaman bu  hatayı alıyorum.
cat /etc/lsb-release
dpkg -l | egrep 'nvidia|bumblebee|primus'
Çevrimdışı damocles
  • İleti: 14
01:00.0 3D controller: NVIDIA Corporation GK208M [GeForce GT 720M] (rev ff)
DISTRIB_ID=LinuxMint
DISTRIB_RELEASE=17
DISTRIB_CODENAME=qiana
DISTRIB_DESCRIPTION="Linux Mint 17 Qiana"
[ 1370.980412] [DEBUG]Reading file: /etc/bumblebee/bumblebee.conf
[ 1370.981669] [DEBUG]optirun version 3.2.1 starting...
[ 1370.981746] [DEBUG]Active configuration:
[ 1370.981780] [DEBUG] bumblebeed config file: /etc/bumblebee/bumblebee.conf
[ 1370.981816] [DEBUG] X display: :8
[ 1370.981848] [DEBUG] LD_LIBRARY_PATH:
[ 1370.981880] [DEBUG] Socket path: /var/run/bumblebee.socket
[ 1370.981912] [DEBUG] Accel/display bridge: auto
[ 1370.981946] [DEBUG] VGL Compression: proxy
[ 1370.981978] [DEBUG] VGLrun extra options:
[ 1370.982010] [DEBUG] Primus LD Path: /usr/lib/x86_64-linux-gnu/primus:/usr/lib/i386-linux-gnu/primus
[ 1370.982145] [DEBUG]Using auto-detected bridge primus
[ 1372.246153] [INFO]Response: Yes. X is active.
[ 1372.246169] [INFO]Running application using primus.
[ 1372.246422] [DEBUG]Process glxgears started, PID 2958.
# to take effect.
[bumblebeed]
VirtualDisplay=:8
# server exits.
# be ignored.
Driver=
[optirun]
# primus.
Bridge=auto
VGLTransport=proxy
# the primus bridge
# is not available?
[driver-nvidia]
PMMethod=auto
[driver-nouveau]
PMMethod=auto
    Driver      "nvidia"
    BusID "PCI:01:00:0"
ii  bumblebee                                   3.2.1-5                                             amd64        NVIDIA Optimus support for Linux
ii  primus                                      0~20131127-2                                        amd64        client-side GPU offloading for NVIDIA Optimus
ii  primus-libs:amd64                           0~20131127-2                                        amd64        Shared libraries for primus
Aşağıdaki komutlar ile nvidia-331 ve nvidia-settings paketlerini kurup aşağıda bahsedilen düzenlemeleri yapınız.
sudo apt-get install nvidia-331 nvidia-settings
Sonra aşağıdaki komut ile bumblebee.conf dosyasını açınız.
Açılan dosyada aşağıdaki şekilde başlayan satırları bulunuz,
KernelDriver=
LibraryPath=
XorgModulePath=
ilgili satırları aşağıdaki şekilde düzenleyerek dosyayı kaydediniz.
Aşağıdaki komutla bumblebee servisini yeniden başlatınız.
« Son Düzenleme: 20 Temmuz 2014, 15:14:14 Gönderen: Butterfly »
Çevrimdışı damocles
  • İleti: 14
Link açılmıyor.
Mesajın devamında yazılanları uyguladınız mı? Bağlantı vermek vermek yerine mesajın altına yazmayı tercih etmişim zaten. Şimdi bağlantıyı sildim siz mesajı devamında yazılanları uygulayın.
Çevrimdışı AtamanAydogdu
  • İleti: 2
Böyle bir hata alıyorum.
optirun glxgears
[ 6665.046408] [ERROR]Cannot access secondary GPU - error: Could not load GPU driver
[ 6665.046476] [ERROR]Aborting because fallback start is disabled.
[ 6517.428557] [DEBUG]Reading file: /etc/bumblebee/bumblebee.conf
[ 6517.429552] [DEBUG]optirun version 3.2.1 starting...
[ 6517.429610] [DEBUG]Active configuration:
[ 6517.429652] [DEBUG] bumblebeed config file: /etc/bumblebee/bumblebee.conf
[ 6517.429696] [DEBUG] X display: :8
[ 6517.429737] [DEBUG] LD_LIBRARY_PATH:
[ 6517.429779] [DEBUG] Socket path: /var/run/bumblebee.socket
[ 6517.429821] [DEBUG] Accel/display bridge: auto
[ 6517.429863] [DEBUG] VGL Compression: proxy
[ 6517.429907] [DEBUG] VGLrun extra options:
[ 6517.429950] [DEBUG] Primus LD Path: /usr/lib/x86_64-linux-gnu/primus:/usr/lib/i386-linux-gnu/primus
[ 6517.430138] [DEBUG]Using auto-detected bridge primus
[ 6517.433859] [INFO]Response: No - error: Could not load GPU driver
[ 6517.433880] [ERROR]Cannot access secondary GPU - error: Could not load GPU driver
[ 6517.433888] [DEBUG]Socket closed.
[ 6517.433913] [ERROR]Aborting because fallback start is disabled.
[ 6517.433923] [DEBUG]Killing all remaining processes.
00:02.0 VGA compatible controller: Intel Corporation Haswell-ULT Integrated Graphics Controller (rev 09)
0a:00.0 3D controller: NVIDIA Corporation GK208M [GeForce GT 740M] (rev a1)
DISTRIB_RELEASE=17
# to take effect.
[bumblebeed]
VirtualDisplay=:8
# server exits.
# be ignored.
Driver=
[optirun]
# primus.
Bridge=auto
VGLTransport=proxy
# the primus bridge
# is not available?
[driver-nvidia]
PMMethod=auto
[driver-nouveau]
PMMethod=auto
    Driver      "nvidia"
    BusID "PCI:0a:00:0"
ii  nvidia-331                                  331.38-0ubuntu7                                     amd64        NVIDIA binary driver - version 331.38
ii  nvidia-libopencl1-331                       331.38-0ubuntu7                                     amd64        NVIDIA OpenCL Driver and ICD Loader library
ii  nvidia-opencl-icd-331                       331.38-0ubuntu7                                     amd64        NVIDIA OpenCL ICD
ii  nvidia-settings                             331.20-0ubuntu8                                     amd64        Tool for configuring the NVIDIA graphics driver
ii  primus                                      20131127-1~trustyppa1                               amd64        client-side GPU offloading for NVIDIA Optimus
ii  primus-libs:amd64                           20131127-1~trustyppa1                               amd64        Shared libraries for primus
Aşağıdaki komutları sırasıyla uçbirimde çalıştırıp nvidia-prime paketini kaldırmayı deneyiniz.
Aşağıdaki komut ile /etc/bumblebee/bumblebee.conf dosyasını açınız.
Aşağıdaki satırı bulup,
Driver=
Aşağıdaki şekilde değiştiriniz ve dosyayı kaydediniz.
Driver=nvidia
  • İleti: 2
Belirttiğiniz değişiklikleri yaptıktan sonra böyle bir hata aldım.
optirun glxgears
[10346.897246] [ERROR]Cannot access secondary GPU - error: [XORG] (EE)
[10346.897288] [ERROR]Aborting because fallback start is disabled.
Aşağıdaki komut ile xorg.conf.nvidia dosyasını açınız.
sudo gedit /etc/bumblebee/xorg.conf.nvidia
Açılan dosyada aşağıdaki satırı bulunuz,
BusID "PCI:0a:00:0"
aşağıdaki şekilde değiştirip dosyayı kaydediniz.
BusID "PCI:0a:00.0"
Çevrimdışı Çağrı07
  • İleti: 391
    • Kayıt Formu
  • Masaüstü Ortamı: XFCE
Önce nvidia sürücülerini kaldırıp yeniden başlattım ve blumbelee'yi kurdum.Yalnız uygulama açılmadı ve çıktılar aynen şöyle
[ 1072.475079] [DEBUG]Reading file: /etc/bumblebee/bumblebee.conf
[ 1072.475637] [INFO]Configured driver: nvidia
[ 1072.475894] [DEBUG]optirun version 3.2.1 starting...
[ 1072.475939] [DEBUG]Active configuration:
[ 1072.475963] [DEBUG] bumblebeed config file: /etc/bumblebee/bumblebee.conf
[ 1072.475987] [DEBUG] X display: :8
[ 1072.476034] [DEBUG] LD_LIBRARY_PATH: /usr/lib/nvidia-304:/usr/lib32/nvidia-304
[ 1072.476058] [DEBUG] Socket path: /var/run/bumblebee.socket
[ 1072.476081] [DEBUG] Accel/display bridge: auto
[ 1072.476103] [DEBUG] VGL Compression: proxy
[ 1072.476125] [DEBUG] VGLrun extra options:
[ 1072.476148] [DEBUG] Primus LD Path: /usr/lib/x86_64-linux-gnu/primus:/usr/lib/i386-linux-gnu/primus
[ 1072.476240] [DEBUG]Using auto-detected bridge primus
[ 1072.509174] [INFO]Response: No - error: [XORG] (EE) NVIDIA(0): Failed to initialize the NVIDIA GPU at PCI:1:0:0.  Please
[ 1072.509246] [ERROR]Cannot access secondary GPU - error: [XORG] (EE) NVIDIA(0): Failed to initialize the NVIDIA GPU at PCI:1:0:0.  Please
[ 1072.509288] [DEBUG]Socket closed.
[ 1072.509358] [ERROR]Aborting because fallback start is disabled.
[ 1072.509411] [DEBUG]Killing all remaining processes.
# to take effect.
[bumblebeed]
VirtualDisplay=:8
# server exits.
# be ignored.
Driver=nvidia
[optirun]
# primus.
Bridge=auto
VGLTransport=proxy
# the primus bridge
# is not available?
[driver-nvidia]
KernelDriver=nvidia-304
PMMethod=auto
LibraryPath=/usr/lib/nvidia-304:/usr/lib32/nvidia-304
XorgModulePath=/usr/lib/nvidia-304/xorg,/usr/lib/xorg/modules
[driver-nouveau]
PMMethod=auto
    Driver      "nvidia"
BusID "PCI:01:00:0"
« Son Düzenleme: 25 Temmuz 2014, 01:56:12 Gönderen: Çağrı07 »
Yaşlanıyorum...
[member=575]Çağrı07[/member], buradaki düzenlemeyi yapmayı deneyiniz.
Çevrimdışı Çağrı07
  • İleti: 391
    • Kayıt Formu
Sistemimi aynı işletim sistemi ile formatladım ve denilenleri baştan sona yaptım fakat bumblebee uygulaması yeniden açılmadı.
Ben de sizin en son bana verdiğiniz komut ile nvidia-304 sürücüsünü kaldırdım ve denilenleri yaptım fakat bumblebee uygulaması açılmadı
Çıktılar aynen şöyle, sizce sorun nerede ?
[  341.385190] [DEBUG]Reading file: /etc/bumblebee/bumblebee.conf
[  341.385789] [DEBUG]optirun version 3.2.1 starting...
[  341.385804] [DEBUG]Active configuration:
[  341.385809] [DEBUG] bumblebeed config file: /etc/bumblebee/bumblebee.conf
[  341.385814] [DEBUG] X display: :8
[  341.385818] [DEBUG] LD_LIBRARY_PATH:
[  341.385823] [DEBUG] Socket path: /var/run/bumblebee.socket
[  341.385827] [DEBUG] Accel/display bridge: auto
[  341.385831] [DEBUG] VGL Compression: proxy
[  341.385835] [DEBUG] VGLrun extra options:
[  341.385840] [DEBUG] Primus LD Path: /usr/lib/x86_64-linux-gnu/primus:/usr/lib/i386-linux-gnu/primus
[  341.386048] [DEBUG]Using auto-detected bridge primus
[  342.073727] [INFO]Response: No - error: Could not load GPU driver
[  342.073746] [ERROR]Cannot access secondary GPU - error: Could not load GPU driver
[  342.073751] [DEBUG]Socket closed.
[  342.073774] [ERROR]Aborting because fallback start is disabled.
[  342.073783] [DEBUG]Killing all remaining processes.
[code]
[bumblebeed]
VirtualDisplay=:8
# server exits.
# be ignored.
Driver=
[optirun]
# primus.
Bridge=auto
VGLTransport=proxy
# the primus bridge
# is not available?
[driver-nvidia]
PMMethod=auto
[driver-nouveau]
PMMethod=auto
[/code]
    Driver      "nvidia"
    BusID "PCI:01:00:0"
Yaşlanıyorum...
